will a VG30E bolt up to the transmission for the 4 cylinder out of a pickup
sorry i kinda mis read your post. so you wanna put the vg in a truck that had a 4 cylinder? im pretty sure the vg will bolt up to the auto. not sure if they used a different trans for the manual 4 cylinders or not. someone will chime in im sure. but no fab work. just ecu swap and harness i believe. im sure someone or here has done the swap.
Edited by mluczaj22
