Dizer92Pathfinder Posted August 8, 2012 Share Posted August 8, 2012 Will the VG30E out of a 92 pathfinder bolt up to the transmission in a 92 pickup? Please answer quick I have a guy wanting to buy my old VG30E . Would he have to do alot of Fabrication to get the VG30 into it? Link to comment Share on other sites More sharing options...
mluczaj22 Posted August 9, 2012 Share Posted August 9, 2012 (edited) sorry i kinda mis read your post. so you wanna put the vg in a truck that had a 4 cylinder? im pretty sure the vg will bolt up to the auto. not sure if they used a different trans for the manual 4 cylinders or not. someone will chime in im sure. but no fab work. just ecu swap and harness i believe. im sure someone or here has done the swap. Edited August 9, 2012 by mluczaj22 Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 9, 2012 Share Posted August 9, 2012 not sure I know the trans/transfer case combo new in the crate has different part numbers from the V6 to the 4 cylinder. Oem-surplus used to have them in the crate for sale. Link to comment Share on other sites More sharing options...
mluczaj22 Posted August 9, 2012 Share Posted August 9, 2012 i know its different trans v6 truck 2wd to v6 pathy 4wd. but not too sure about the 4 cylinders. Link to comment Share on other sites More sharing options...
JamesRich Posted August 9, 2012 Share Posted August 9, 2012 The bell housing is different from VG30 to 4 cylinder. James Link to comment Share on other sites More sharing options...
mluczaj22 Posted August 9, 2012 Share Posted August 9, 2012 The bell housing is different from VG30 to 4 cylinder. James do you know if the trans are the same though? Link to comment Share on other sites More sharing options...
JamesRich Posted August 9, 2012 Share Posted August 9, 2012 The internals are probably the same but the case is different. The VG30 won't bolt up to a 4 cylinder transmission if that's what your looking for. James Link to comment Share on other sites More sharing options...
Dizer92Pathfinder Posted August 11, 2012 Author Share Posted August 11, 2012 cool thanks . Link to comment Share on other sites More sharing options...
