1987caddy Posted July 30, 2012 Share Posted July 30, 2012 (edited) I have this squeal on my 95xe that comes and goes. Belts, water pump and the a/c idler pulley were replaced 4 years ago (35k). Everytime I go to remove belts and find noise, its not there. Turning steering wheel and turning a/c off and on makes no difference. I'm stumped http://www.youtube.c...bed/MmzEiMr33aQ Edited July 30, 2012 by 1987caddy Link to comment Share on other sites More sharing options...
NissanNismoZ Posted July 30, 2012 Share Posted July 30, 2012 (edited) I'd it possible one of your belts are just loose? Have you tried removing one belt at a time? alternator whining? Edited July 30, 2012 by NissanNismoZ Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 1, 2012 Share Posted August 1, 2012 Yep...pull 1 at a time and if its still not there put one on and just run single belts...guessing its a loose belt or oily pulley Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 2, 2012 Share Posted August 2, 2012 While you've got the belts off, try spinning the pulleys by hand (including the a/c idler) to check for binding etc. Link to comment Share on other sites More sharing options...
Tungsten Posted August 3, 2012 Share Posted August 3, 2012 Loose belt for sure. Sounds like one of them need more tension. Link to comment Share on other sites More sharing options...
