devonianwalk Posted July 6, 2012 Share Posted July 6, 2012 Hey gang, Like the title of this thread, is it safe to drive a couple of days with out the power steering pump in place? My re-manufactured pump went out less than a month of when I installed it. The "big box" store is honoring the warranty but, they have to order the part which will take a couple of days. Hind sight is 20/20 and I realize that I should have contacted them before removing the pump. I would just like y'alls input before installing the bad pump back on if I don't have to. Link to comment Share on other sites More sharing options...
NissanNismoZ Posted July 6, 2012 Share Posted July 6, 2012 I know someone that drove without one before getting a new one and as long as the pump is already bad what can you damage? Its only safe if you have the strength to handle it.. Link to comment Share on other sites More sharing options...
nunya Posted July 6, 2012 Share Posted July 6, 2012 Remember, your running the rest of the system dry with no pump, not exacty friendly on your rack... I've done it but don't suggest it Link to comment Share on other sites More sharing options...
adamzan Posted July 6, 2012 Share Posted July 6, 2012 You could loop the lines and fill it so at least the rack is lubed. Common mod in the vw world my friend says. Sent from my BlackBerry 9670 using Tapatalk Link to comment Share on other sites More sharing options...
nunya Posted July 6, 2012 Share Posted July 6, 2012 VW people don't count, they rust their cars on purpose! 3 Link to comment Share on other sites More sharing options...
tmoore4512 Posted July 7, 2012 Share Posted July 7, 2012 (edited) You could loop the lines and fill it so at least the rack is lubed. Common mod in the vw world my friend says. I have done this before myself on a few vehicles with rack and pinion steering. Works just fine for what its intended to do. Every dirt track guy that is sporting a 2.3 liter mustang does this as well, the whole point is to keep oil in the rack, thus keeping it alive. Edited July 7, 2012 by tmoore4512 Link to comment Share on other sites More sharing options...
Tungsten Posted July 7, 2012 Share Posted July 7, 2012 Yes, as long as you keep the rack oiled there is nothing that will go wrong running it without a pump. The pump just makes the steering easier by pressurizing the oil against some weight or valve or something like that. Just don't try parallel parking. Well you can but it won't be as easy. You won't break the input shaft though so don't worry about it. Link to comment Share on other sites More sharing options...
devonianwalk Posted July 7, 2012 Author Share Posted July 7, 2012 Thanks for the input fella's. I went ahead and re-installed the busted pump and put a half a quart of fluid in to keep the rack lubed. I get to do the process all over again Tuesday when the next re-man pump comes in. Link to comment Share on other sites More sharing options...
tmoore4512 Posted July 7, 2012 Share Posted July 7, 2012 That works too! Link to comment Share on other sites More sharing options...
Kingman Posted July 8, 2012 Share Posted July 8, 2012 Pain in the ass to drive but it's okay to do. Had to myself for a few months until I could afford a new pump. Link to comment Share on other sites More sharing options...
Tungsten Posted July 9, 2012 Share Posted July 9, 2012 In my experience handling a rack with no pump is slightly easier than handling a box without one. Link to comment Share on other sites More sharing options...
nunya Posted July 9, 2012 Share Posted July 9, 2012 Thanks for the input fella's. I went ahead and re-installed the busted pump and put a half a quart of fluid in to keep the rack lubed. I get to do the process all over again Tuesday when the next re-man pump comes in. Why not drive your other car until it arrives? Wait... Then you would have to be seen in a Miata Link to comment Share on other sites More sharing options...
Tungsten Posted July 9, 2012 Share Posted July 9, 2012 What is this with you and Miata gripe? Link to comment Share on other sites More sharing options...
devonianwalk Posted July 9, 2012 Author Share Posted July 9, 2012 What is this with you and Miata gripe? Nunya's just being an ass. My wife is driving the Miata while I have the head off of her engine because her dang timing belt slipped. Found a complete engine for $100 because the guy put a Vtec in his and dosent want it. Go figure? Link to comment Share on other sites More sharing options...
Trogdor636 Posted July 9, 2012 Share Posted July 9, 2012 Nunya's just being an ass. My wife is driving the Miata while I have the head off of her engine because her dang timing belt slipped. Found a complete engine for $100 because the guy put a Vtec in his and dosent want it. Go figure? Be careful. If he swapped a Vtec in his, I'm betting that motor has some hard, hard miles. Link to comment Share on other sites More sharing options...
devonianwalk Posted July 9, 2012 Author Share Posted July 9, 2012 I just want the head off of it and maybe a few hoses that I cut while removing hers. I'm going to take a pressure gauge with me and turn the crank by hand to see if I can muster up, oh .. what should I get by turning the crank by hand? I'm guessing maybe 25-30 psi? Plus, I'm going to scrap my old head and the "new" engine block. That should be a wash for $100. Link to comment Share on other sites More sharing options...
trexterra Posted July 10, 2012 Share Posted July 10, 2012 VW people don't count, they rust their cars on purpose! hahaha so true... but if the rust is natural then it's not cool Link to comment Share on other sites More sharing options...
Trogdor636 Posted July 10, 2012 Share Posted July 10, 2012 What year and model Honda? Link to comment Share on other sites More sharing options...
devonianwalk Posted July 10, 2012 Author Share Posted July 10, 2012 96 Prelude Link to comment Share on other sites More sharing options...
Trogdor636 Posted July 10, 2012 Share Posted July 10, 2012 Alright. Making sure it wasn't a D17 Civic motor. Those are not worth pulling the head off. Link to comment Share on other sites More sharing options...
