nismopathy93 Posted September 29, 2012 Share Posted September 29, 2012 mine are mounted almost exactly the same way on my pathy and I have never had a problem thus far?? Link to comment Share on other sites More sharing options...
Tungsten Posted September 29, 2012 Share Posted September 29, 2012 I agree with TME The mounts have to be rotated like OEM or those bushings will disappear quickly under steep flexing and the shock will bend. Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted September 29, 2012 Share Posted September 29, 2012 mine are mounted almost exactly the same way on my pathy and I have never had a problem thus far?? Just because you have yours this way doesn't mean it's correct. The shocks are designed to mount like they do stock for a reason. They are designed to pivot on the mount not bind on the mount. 1 Link to comment Share on other sites More sharing options...
stalker Posted October 2, 2012 Author Share Posted October 2, 2012 Good eye TME...those are already cut off...had one of the guys at a local 4x4 shop weld those on because I've been so busy working...long story short. thats not the only thing he F up...just waiting for the new ones to get in...I was using the factory uppers for the rear but now I am going to make a custom upper mounts so I can move the shocks up higher and angle them in a little more... 1 Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted October 2, 2012 Share Posted October 2, 2012 Good eye TME...those are already cut off...had one of the guys at a local 4x4 shop weld those on because I've been so busy working...long story short. thats not the only thing he F up...just waiting for the new ones to get in...I was using the factory uppers for the rear but now I am going to make a custom upper mounts so I can move the shocks up higher and angle them in a little more... Just keep in mind the more you angle them the less they will dampen the bumps. The shock won't compress as much as they would if they where mounted straight up and down. It would almost be like changing the valving in the shocks to a much softer setup. 1 Link to comment Share on other sites More sharing options...
stalker Posted October 2, 2012 Author Share Posted October 2, 2012 (edited) also cut the rear fenders... Edited October 2, 2012 by stalker Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted October 3, 2012 Share Posted October 3, 2012 I want to see a pic of the inside of the fender please. Link to comment Share on other sites More sharing options...
Tungsten Posted October 3, 2012 Share Posted October 3, 2012 Just keep in mind the more you angle them the less they will dampen the bumps. The shock won't compress as much as they would if they where mounted straight up and down. It would almost be like changing the valving in the shocks to a much softer setup. That's correct. A shock is the most efficient when it is directly perpendicular to the road. All axle shocks are a little bit of a compromise though. It really does work better when the shocks are slightly diagonal with an axle for flex reasons. Link to comment Share on other sites More sharing options...
stalker Posted October 3, 2012 Author Share Posted October 3, 2012 I want to see a pic of the inside of the fender please. i can show you a picture before its finished if you like.? i still need to weld in some plate and then it will be finished Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted October 3, 2012 Share Posted October 3, 2012 i can show you a picture before its finished if you like.? i still need to weld in some plate and then it will be finished That's what I want to see. I'm worried about cutting mine that much because I don't know what's behind it. Link to comment Share on other sites More sharing options...
stalker Posted October 3, 2012 Author Share Posted October 3, 2012 That's what I want to see. I'm worried about cutting mine that much because I don't know what's behind it. i will take some pictures later today if i get a chance 1 Link to comment Share on other sites More sharing options...
stalker Posted October 5, 2012 Author Share Posted October 5, 2012 here it is...i know its ugly..it will all be plated in so no water or mud will get in there Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted October 5, 2012 Share Posted October 5, 2012 cool deal. Thanks man. Hopefully I'll be getting new MIG welder and a combo plasma cutter TIG welder soon. When I do I'll be cutting the rear quarter to angle it up toward the bumper I built. Link to comment Share on other sites More sharing options...
nismopathy93 Posted October 6, 2012 Share Posted October 6, 2012 I am gonna do the same thing to my rear due to moving my axle back a bit so it will stuff the 39.5s up in there better!! Link to comment Share on other sites More sharing options...
stalker Posted October 29, 2012 Author Share Posted October 29, 2012 here is a couple little text flexing going on...need to move the front shock hoops up higher...the shocks are bottoming out...but it will be an easy fix for that Link to comment Share on other sites More sharing options...
nismopathy93 Posted October 31, 2012 Share Posted October 31, 2012 good to see it out of the shop dont for get to send me some more pics with the front drive line and shocks moved!! Now that you moved that hanger your tg springs have your axle sitting right where my springs would have put it so that is a good thing too!!! still too bad that you had to fix that stuff!! keep me posted on your buddy too!! Link to comment Share on other sites More sharing options...
stalker Posted November 5, 2012 Author Share Posted November 5, 2012 (edited) I am trying to make a run at Path of the Year.! one of my Wheeling buds Cherokee Edited November 5, 2012 by stalker Link to comment Share on other sites More sharing options...
Slartibartfast Posted November 6, 2012 Share Posted November 6, 2012 (edited) Go home, Pathfinder. You're drunk. Also, I see you're not the only one who likes olive drab. Edited November 6, 2012 by Slartibartfast Link to comment Share on other sites More sharing options...
stalker Posted November 6, 2012 Author Share Posted November 6, 2012 You like that flex ramp...should have seen the neighbors glaring at us.. 1 Link to comment Share on other sites More sharing options...
stalker Posted December 11, 2012 Author Share Posted December 11, 2012 Link to comment Share on other sites More sharing options...
stalker Posted December 12, 2012 Author Share Posted December 12, 2012 so i got the front drive shaft installed and now im needing to re-route the Y pipe so it will clear when flexing...does anyone have any pictures or ideas for the re-routing.? thanks Link to comment Share on other sites More sharing options...
nismopathy93 Posted December 15, 2012 Share Posted December 15, 2012 I will send you pics tomorrow of my hb I cut apart the factory y pipe rotated it up bought a 90 and used some of the old pipe and made it all work Link to comment Share on other sites More sharing options...
stalker Posted December 19, 2012 Author Share Posted December 19, 2012 finished up the Y pipe.. you can see where my front drive shaft was rubbing on the section of flex pipe i put in there temporally Link to comment Share on other sites More sharing options...
nismopathy93 Posted December 20, 2012 Share Posted December 20, 2012 much sexier then mine i had no bender and used old pipe lol!! Link to comment Share on other sites More sharing options...
stalker Posted February 6, 2013 Author Share Posted February 6, 2013 Well my steering felt like it was gong to break something when I locked into 4wheel yesterday...I was on dry pavement and couldn't turn the wheels without the steering feeling locked up...I unlocked the hubs and it was working fine again...time to dig into this a little more... any ideas..? Link to comment Share on other sites More sharing options...
