edicer2 Posted April 19, 2012 Share Posted April 19, 2012 So i was driving at night with my headlights on and all of the sudden my pass side headlight went out so i hurried home so i wouldnt get a ticket or something dumb for that. At first i thought it was my bulb or the ballast from my projectors but those tested out fine it was my factory headlight socket. I am not getting power to it and before anyone goes off and says my HIDs wrecked it I would like to say i dont think they did since i only had the low beams hooked up and the high beam doesnt get power on that socket either or in the wires on the way to the socket. Could this be a relay problem or might it be something deeper? I have never messed with the relays for the headlights so i will need to figure out where they are. I do still have pretty much all the relays from my old pathfinder but not sure if thats it or not. Anyone else have this problem and what was the fix? Right now i fixed it with a relayed harness that uses my passenger side socket as a trigger to turn them on and it pulls power from the battery instead but would like to have both sockets working for if i ever want to switch back to the other way. Link to comment Share on other sites More sharing options...
silverton Posted April 19, 2012 Share Posted April 19, 2012 Have you checked your headlight stalk? Those are known to fail, and is the main reason to make the switch to a relay harness. Link to comment Share on other sites More sharing options...
Puckstoper9 Posted April 19, 2012 Share Posted April 19, 2012 If i remember correctly there are not factory relays for the head lights. the factory system runs through the headlight switch only. Link to comment Share on other sites More sharing options...
edicer2 Posted April 19, 2012 Author Share Posted April 19, 2012 hmm bummer so that would fail for both the high and low beam or only 1 side? Link to comment Share on other sites More sharing options...
nunya Posted April 19, 2012 Share Posted April 19, 2012 when they fail they normally wipe out power from 1 low beam and one high beam, leavign 1 of each brightness still working (most commonly on opposite sides) Link to comment Share on other sites More sharing options...
Balln Posted April 20, 2012 Share Posted April 20, 2012 I had some wacky problems with my high and low beams. I ended up just replacing the whole light switch that attachs to the steering column and no more problems. Link to comment Share on other sites More sharing options...
Trogdor636 Posted April 20, 2012 Share Posted April 20, 2012 I had some wacky problems with my high and low beams. I ended up just replacing the whole light switch that attachs to the steering column and no more problems. You can actually take that apart and clean it, its fixed my headlight issue on every Hardbody I have ever owned. Has not happened on the Pathy yet. Link to comment Share on other sites More sharing options...
edicer2 Posted April 20, 2012 Author Share Posted April 20, 2012 ok cool I will try cleaning the headlight switch thanks guys ik thats a common problem on my z31's but wasnt sure the newer nissans had that issuse too Link to comment Share on other sites More sharing options...
Balln Posted April 24, 2012 Share Posted April 24, 2012 You can actually take that apart and clean it, its fixed my headlight issue on every Hardbody I have ever owned. Has not happened on the Pathy yet. Yeah I took it apart and cleaned it. Mine had some of that white electrical grease in it so I cleaned all that out real good and added new grease same kind and it did work for about a week then it started acting up again so I said screw it and bought a new one. Link to comment Share on other sites More sharing options...
edicer2 Posted April 24, 2012 Author Share Posted April 24, 2012 (edited) what one would i want? I have a 92 SE v6 vg30e 5 speed manual 4x4 offroad. I am not sure if i need the top left or top right? its on a non cali also i am in MN and this was bought in nebraska if that helps. I guess i could pop my out and see if i have that extra cord on it. http://www.courtesyp..._5573_5611_5616 Edited April 24, 2012 by edicer2 Link to comment Share on other sites More sharing options...
adamzan Posted April 24, 2012 Share Posted April 24, 2012 Ones for with cruise one for without. Link to comment Share on other sites More sharing options...
blackspawn Posted April 24, 2012 Share Posted April 24, 2012 My truck did that once, and I found the wires on the positive side of the battery was kinda loose. One of them was feeding one side of the headlights. I have a 90 Pathy if that helps. Link to comment Share on other sites More sharing options...
edicer2 Posted April 26, 2012 Author Share Posted April 26, 2012 (edited) yeah i have cruse that works so i will want to keep that feature. I will check my terminals but i am pretty sure its the switch like others have said. Only one way to tell i gues ill check the battery tonight if that doesnt fix it ill just buy a new switch since they are cheap only like 60 bucks. Is the one with cruise the one with the blue wire on it? Edited April 26, 2012 by edicer2 Link to comment Share on other sites More sharing options...
