Rear Sway Bar Bushing
William
Hi Guys :)
I am looking for a set of new Rear Sway Bar Bushings for my WD21
and came across a set by SuperPro (Australia). The problem
is they offer that same Bushing with 4 different inner diameters:
Bar diameter: 23,25,26,29mm available
So which one is it please?
William
  • 1 year later...
The easiest way I know to find out is to get a set of calipers and measure the sway bar where it is clean. this should give you the bar diameter on your rig. I know with GM products at the dealership I work at they throw different sway bar sizes at nearly identical trucks otherwise. Hope this helps, D
