New fog lights, old wiring, no power?
NissanNismoZ
Alright. Did the R50 console swap, works great!
In the process I unhooked my fog lights switch..and forgot the order. So I went through 6 fuses before finding the correct order.
Alright, got the regular fogs in an working. So far do good. Couldn't mount them so I bought a new set. Wired them in before mounting, and good. Mounted them in and now they will NOT power on. Fog switch is illuminated, and as far as I know if a fog light blows a fuse, it'll take the fuse to the headlight with it.
Any ideas? Fuses are good.. But the lights won't turn on now...
Thanks! I'd really rather stick with stock wiring.. But..hopefully there's a fuse I may not know about?
Thanks!
I don't know of any fuses other than under the dash. So the head lights work?
You need a tester, preferably a multimeter but even 2 pins/wires taped to a 12 volt bulb would work.Ttest to see if you have power to the new lights, then backtrack the wiring if you don't.
Behind the battery in very non factory looking fuse holder is your fog light fuse. Fog lights were a dealer installed factory option, so nothing under the dash.
Edited by Trogdor636
Correct.
I had foglights plugged in to my truck, they didn't work. But I didn't look in to the issue much farther.
It almost sounds like a ground issue if the switch is illuminated but no power to the lights. I would check all of the connections, and make sure that there is not a build up of corrosion somewhere in line (IE at a splice, butt connector etc.)
If you haven't already, I'd check that length of wire by the fuse holder. The wire is grounding out somewhere. I think the relay is on the firewall on the passenger side, its probably a Bosch unit if its still the stock one. Check that area as well.
Fixed.
Apparently my friends fog light he was wiring was wired up backwards..
So I replaced the fuse with a 15A again and cleaned up the wiring mess and tada! They work! And are extremely bright..:)
Thanks guys! I really appreciate the help!
