Redneck Rust repair?
DantheMayun
Truck is road worthy again and I want to get rid of the nasty hole in rear driver fender.... I used a tin can before and bondo and sorta shaped up over the rust. Long story short I cut it out because i thought it was a stupid idea but now I'm short of a welder. Any ideas for a clean looking patch that would last me a couple of years? I want to make it look nice
Pics to come soon
Never cover rust with putty, it'll just keep eating the metal, and then the putty starts flaking off. Grind off as much rust as you can before going at it. Then... fiberglass?
Or, so long as you're looking for redneck fixes, put a NASCAR sticker over it and call it good enough. :D
Edited by Slartibartfast
I've used expanding spray insulation, I would recommend a rust converter like POR 15 to stop it from spreading and use the foam, let it set and use enough it comes out the hole. Use a hack saw blade to cut off the excess and that will give filler something to go against, I don't know how big of hole your tryin to fill but that will work for looks but won't be that strong. If you are looking for strength out of filler I would guess it needs to be 1/4 in. And that's just guessing from playing with it after it hardens
yup yup. In D.C. they have a law that your vehicle can't have any rust showing.
I sure do see a lot of cars with their rocker panels covered in bumper stickers. Hmm..
But seriously, if you don't fix it properly, the rust will just get worse. You might want to try something like this.
