Tungsten Posted January 24, 2012 Share Posted January 24, 2012 My wheel makes grinding and crunching noises when I turn it. Is there any way to fix this? Both wheels still turn as far as I know. Link to comment Share on other sites More sharing options...
unccpathfinder Posted January 24, 2012 Share Posted January 24, 2012 I think you need more details than that... 1. Can you tell whether the grinding is under the hood or in the cab if its in the cab it may be something to do with the ring for the horn/cruise or the clamshell (steering column cover)or turn signal cancel if its under the hood did you check the U joints for debris/wear 2. which wheel...steering wheel...or actual wheels 3. more details on the sound and when it happens... Link to comment Share on other sites More sharing options...
Tungsten Posted January 24, 2012 Author Share Posted January 24, 2012 To answer your questions: 1. In the cab, from the steering wheel itself. 2. The steering wheel. 3. Happens as I am turning the wheel. Feels like something lost its lubrication or the bearing exploded. Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 24, 2012 Share Posted January 24, 2012 (edited) First thing I'd check is the sliding contact setup for the horn/cruise/etc. Mine sounds a little crunchy from the crap accumulated in there. Edited January 24, 2012 by Slartibartfast Link to comment Share on other sites More sharing options...
adamzan Posted January 24, 2012 Share Posted January 24, 2012 My wheel makes grinding and crunching noises when I turn it. Is there any way to fix this? Both wheels still turn as far as I know. That is one of the dumber things I've read on here in a while. Link to comment Share on other sites More sharing options...
devonianwalk Posted January 24, 2012 Share Posted January 24, 2012 That is one of the dumber things I've read on here in a while. You obviously don't read any of my posts then! Link to comment Share on other sites More sharing options...
NissanNismoZ Posted January 24, 2012 Share Posted January 24, 2012 That is one of the dumber things I've read on here in a while. haha...yeah.. but. mine does the same thing occasionally, i think mine seems to be the cancel gears for the turn signal...if you find a fix, let us know? Link to comment Share on other sites More sharing options...
Trogdor636 Posted January 24, 2012 Share Posted January 24, 2012 First thing I'd check is the sliding contact setup for the horn/cruise/etc. Mine sounds a little crunchy from the crap accumulated in there. This is where I'd start. My wheel is starting to make a bit of noise I've just been too lazy to do anything about it yet. Link to comment Share on other sites More sharing options...
Tungsten Posted January 25, 2012 Author Share Posted January 25, 2012 (edited) First thing I'd check is the sliding contact setup for the horn/cruise/etc. Mine sounds a little crunchy from the crap accumulated in there. I checked that today, it even does that if I rip the horn box out. You can literally just pull them out on earlier models! The noise is most audible between the steering column and the steering wheel. It sounds like you are rubbing two pieces of paper or two pieces of hard plastic together or something like that and it's really irritating. Before I thought that the steering wheel was rubbing on the column but now I don't know. I removed everything from the wheel today and tried turning it and nothing changed. That is one of the dumber things I've read on here in a while. To adamzan: relax dude, I was tired. That was a joke. haha...yeah.. but. mine does the same thing occasionally, i think mine seems to be the cancel gears for the turn signal...if you find a fix, let us know? Maybe but I have it all the time. Looks like I will be taking my steering wheel off next. Edited January 25, 2012 by Tungsten Link to comment Share on other sites More sharing options...
1994SEV6 Posted January 25, 2012 Share Posted January 25, 2012 That is one of the dumber things I've read on here in a while. :rofl: HAHAHAHAHLOLOL..hahahaha... I don't get it... Column grinding, eh? Have you tossed $1 bills at your steering wheel lately? Link to comment Share on other sites More sharing options...
Tungsten Posted January 25, 2012 Author Share Posted January 25, 2012 *throws money at the screen* nothing happens Link to comment Share on other sites More sharing options...
Trogdor636 Posted January 25, 2012 Share Posted January 25, 2012 This might be a dumb question, but is the steering wheel tight? Link to comment Share on other sites More sharing options...
JamesRich Posted January 25, 2012 Share Posted January 25, 2012 Just start tearing it apart. Remove parts till you find the problem. James Link to comment Share on other sites More sharing options...
Tungsten Posted February 10, 2012 Author Share Posted February 10, 2012 This may sound weird but that problem went away by itself. If it comes back I'm going to put some grease down the shaft or something. Link to comment Share on other sites More sharing options...
1994SEV6 Posted February 11, 2012 Share Posted February 11, 2012 yes. greasing the shaft often helps with grinding. Link to comment Share on other sites More sharing options...
Tungsten Posted March 1, 2012 Author Share Posted March 1, 2012 I found the problem... They were the horn contacts behind the steering wheel. Just a quick conductive grease and the noise is gone. Sounds pretty scary without it. Link to comment Share on other sites More sharing options...
unccpathfinder Posted March 1, 2012 Share Posted March 1, 2012 Thanks for posting results...makes me feel accomplished sometimes Link to comment Share on other sites More sharing options...
