elieaazan Posted November 18, 2011 Share Posted November 18, 2011 Hi guys , i have a 1994 wd21 i already installed "ironman" suspension it gave me abou7 2 inch lift . now i want to move to 33" 12.5" 15" tires . is a 2 inch body lift enaugh ? or i need a 3 inch body lift ? and what are the negative effects of the doby lift and 33" tires ??\ thanks.... Link to comment Share on other sites More sharing options...
headpeace Posted November 18, 2011 Share Posted November 18, 2011 go with the 3" BL. Link to comment Share on other sites More sharing options...
madhornet Posted November 25, 2011 Share Posted November 25, 2011 go with the 3" BL. agreed Link to comment Share on other sites More sharing options...
elieaazan Posted November 25, 2011 Author Share Posted November 25, 2011 thanks guys . But does BL have any disadvantages?? Link to comment Share on other sites More sharing options...
sewebster Posted November 25, 2011 Share Posted November 25, 2011 thanks guys . But does BL have any disadvantages?? Your truck is higher up so you probably have more chance of rolling over, perhaps more body roll etc. Worse fuel economy due to increased aero drag... harder to climb into the cab. But how big each of these concerns are is not known to me Link to comment Share on other sites More sharing options...
1994SEV6 Posted November 26, 2011 Share Posted November 26, 2011 thanks guys . But does BL have any disadvantages?? Sewebster covered a few of them. Pretty much..Less payload. Less MPGs. Parts will fail faster. Wheel bearings will go bad faster. Link to comment Share on other sites More sharing options...
Kingman Posted November 26, 2011 Share Posted November 26, 2011 (edited) Sewebster covered a few of them. Pretty much..Less payload. Less MPGs. Parts will fail faster. Wheel bearings will go bad faster. What? Body lift affects nothing in the suspension. They raise the body further off the frame. Parts will not fail faster and neither will wheel bearings. The 33s will probably slow the rig down some due to the added weight and circumference, as well as throw your speedometer and odometer off a little. Edited November 26, 2011 by Kingman 1 Link to comment Share on other sites More sharing options...
Kafike Posted November 26, 2011 Share Posted November 26, 2011 Kingman is correct. A suspension lift will alter CV angles wearing out parts much faster. A body lift will not affect suspension components. Link to comment Share on other sites More sharing options...
elieaazan Posted November 27, 2011 Author Share Posted November 27, 2011 thanks guys . So i'll go for 3 inch BL with 33 tires +4.65 ring pignon Link to comment Share on other sites More sharing options...
