Tungsten Posted September 30, 2011 Share Posted September 30, 2011 (edited) It looks like my V-belts are showing their age again... So here is my question: Out of all the V-belts, which ones do you run and why? I ran Nissan (Bando), Gates, and Dayco belts so far and all of them seem to last about the same before they start to go bad or show signs of wear and tear. I need something that won't shred in the 5000-6000 rpm range. Edited September 30, 2011 by Tungsten 1 Link to comment Share on other sites More sharing options...
lint Posted September 30, 2011 Share Posted September 30, 2011 Bando. Quality & I can get them through my online supplier for a great price. Link to comment Share on other sites More sharing options...
Tungsten Posted September 30, 2011 Author Share Posted September 30, 2011 How long does that last for you? All the A/C belts have had an average life of 20,000 miles for me before they started to make noise or lose chunks. The other 2 belts seem to last a little longer than that. 1 Link to comment Share on other sites More sharing options...
RJSquirrel Posted September 30, 2011 Share Posted September 30, 2011 I've always had good results with Gates. Link to comment Share on other sites More sharing options...
Trogdor636 Posted September 30, 2011 Share Posted September 30, 2011 I've always had good results with Gates. Same. Plus if I need one same day, my local O'reillys carries Gates, and Gates actually makes belts for Napa. Link to comment Share on other sites More sharing options...
Tungsten Posted October 1, 2011 Author Share Posted October 1, 2011 Cool! My shop also recommended Gates belts so I think I might go with that. I had Dayco belts before and liked how they sank into the pulleys but don't mind trying Gates. I had great luck with Gates cooling system hoses too. 1 Link to comment Share on other sites More sharing options...
adamzan Posted October 3, 2011 Share Posted October 3, 2011 What the hell are you doing to wear out the belts so fast. Are your pulleys misaligned or something. I still have the belts I put on the truck 4 years ago and they are fine. Link to comment Share on other sites More sharing options...
Tungsten Posted October 3, 2011 Author Share Posted October 3, 2011 I don't know but the A/C belt for some reason wears out only after 20,000 miles. The other belts still look like new. It has been a mystery but when I googled the issue it seems some Pathfinders just eat the A/C belts right up. My A/C clutch doesn't stick and the idler pulley free wheels just fine. Maybe there isn't enough tension on the A/C belt? 1 Link to comment Share on other sites More sharing options...
adamzan Posted October 3, 2011 Share Posted October 3, 2011 Maybe it is too tight. Link to comment Share on other sites More sharing options...
Tungsten Posted October 3, 2011 Author Share Posted October 3, 2011 Usually belts will shred if they are too loose and pulleys don't last if the belts are too tight. Either way too loose or too tight is never good news so I will check the belt deflection again with new belts. 1 Link to comment Share on other sites More sharing options...
sewebster Posted October 3, 2011 Share Posted October 3, 2011 20000 miles is more than 4 years for me Link to comment Share on other sites More sharing options...
Tungsten Posted October 3, 2011 Author Share Posted October 3, 2011 20,000 miles is 1 year of driving for me. Link to comment Share on other sites More sharing options...
Precise1 Posted October 3, 2011 Share Posted October 3, 2011 Usually belts will shred if they are too loose and pulleys don't last if the belts are too tight. Either way too loose or too tight is never good news so I will check the belt deflection again with new belts. Always error on the side of too loose VS too tight, the components will last longer. B Link to comment Share on other sites More sharing options...
