sewebster Posted September 15, 2011 Share Posted September 15, 2011 So, "everyone" always says that you can't put a locker in a WD21 rear diff with LSD, so an advantage of having an open diff is that at least you can put a locker in it. In another thread in the R50 section: http://www.nissanpathfinders.net/forum/index.php?showtopic=31208 This was questioned... but no one responded. What is the incompatibility with the LSD? Link to comment Share on other sites More sharing options...
fleurys Posted September 15, 2011 Share Posted September 15, 2011 (edited) there is 2 types of lockers.... the one you add hardware between the spider gears (like a lock right locker) and the one where you completely change the heart or core of the differential (like an arb locker). Now an lsd "core" has already friction disks between the spider gear rendering it unusable to install the lockright locker type. But then again, maybe the inners of the lsd could be removed, but I don't know about that.... maybe the "core" is different and does not give access to insert anything..see the picture .. as for an ARB type of locker, having an lsd or not does not prevent you from installing since you are changing the whole "core" and only keeping the ring gear. Hope this helps.. Edited September 15, 2011 by fleurys Link to comment Share on other sites More sharing options...
KovemaN Posted September 15, 2011 Share Posted September 15, 2011 The "core" of the LSD diff is smaller in diameter than the open diff. I think that Richmond made the right decision to use the open diff for the locker. The LSD diff would have a much smaller locking engagement surface. Link to comment Share on other sites More sharing options...
sewebster Posted September 15, 2011 Author Share Posted September 15, 2011 Ah, right, so the thing that is incompatible is the large housing (shown in fleurys second pic) that the ring gear bolts on to... the part that spins around on the big bearings also shown in the pic. Link to comment Share on other sites More sharing options...
silverton Posted September 15, 2011 Share Posted September 15, 2011 Someone is going to be producing (or produces) a locker for the LSD carrier on the Xterra, just because you're going to be hard pressed to find an Xterra with an open diff. Link to comment Share on other sites More sharing options...
sewebster Posted September 19, 2011 Author Share Posted September 19, 2011 So, as Fleurys said, it seems that arb provides the carrier, and thus you can use an arb locker in a oem LSD diff. Seems this might be a fairly big revelation around here... or maybe people just prefer other types of lockers... Perhaps modern electronic traction control makes all this obsolete though (brake the spinning wheel only). Link to comment Share on other sites More sharing options...
adamzan Posted September 19, 2011 Share Posted September 19, 2011 People usually want the easiest cheapest thing they can find that will work. Though I am not of this mentality lol. Link to comment Share on other sites More sharing options...
