Jim Wolf S1 Cams?
The_Magicians_Eye
Does anyone have these cams in their ride? If so how much did it help power wise? Do you think it was worth the money? I need more power. That's it plane and simple. I'm looking for the most bang for my buck. I don't like how hard my truck has to work to tow my trailer. Even empty it struggles on any type of hill. Here is what I've done so far: headers, hi-flow cat, 2 chamber muffler, K&N filter, I made by breather box look like swiss cheese with a 2 inch hold saw, made sure my alignment was right on point, and all basic maintenance items have been replaced (fuel filter, plugs, wires, cap, rotor). Outside of new cams and getting the computer rebuilt I don't know what else to do.
Help!!!!!
Can you tell me what your exhaust setup is exactly? Also, can you make an acceleration video?
Here is the Cat I have. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__16120076-P_145_R|GRPEXHAAMS____
Here is the Muffler I have. My linkhttp://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__20291344-P_N3333C_P|GRP2023P____
And I have Pacesetter headers.
The rest of the pipe is stock.
I have a few video posted on my youtube channel that will give you an idea of how it sounds in action. http://www.youtube.com/UvisionMedia
Hope that helps you.
You've done the basics have you considered putting a vg33 block in ? I made that swap a while back made a pretty significant difference after all the other stuff. I got a long block for about 600 in cali. You should be able to find something around there. Nissannut has a write up on his website that does a pretty good job going over how to do it. Or you could always turbo it. :)
Both these may be part of the issue. Some PaceSetters have a restriction at the Y, from welding IIRC and the stock pipe doesn't allow much flow. Remember, with exhaust you want flow with little turbulance and the single choke point sets the gains for the whole system. That said, some back pressure is desirable for a daily driver AFAIAC.
Well then maybe there is something wrong. I did a test run with an empty 5x8 enclosed trailer (single axle) and it did fine on flat roads. On any type of hill it was bad enough for me to worry about towing it with it loaded down.
Anyone in Phoenix willing to let me take their ride for a spin to see if it's got more power than mine?
