Gearing Changes?
The_Magicians_Eye
Can you just change the gearing in your transfer case rather than having to change the gears in both the front and rear dif? And do they offer new speedometer gears to correct it for lower gearing? What is a good lower gear setup that would still work fine on the highway?
The speedometer gear is in the transfer case, so I don't think it matters what gears you put in the transfer case. they make lower gear kits for our TX-10 though. High will also be 1:1 though.
