jwmyers23 Posted July 21, 2011 Share Posted July 21, 2011 (edited) Ok heres on for you guys and gals. My 95 XE auto started doing something weird. When I let my foot off the gas and the idle drops down to 1000 RPM's it starts to buck or hicup. It only does it with the overdrive on. Would could it be? http://youtu.be/5IOSeWyoVFw Edited July 21, 2011 by jwmyers23 Link to comment Share on other sites More sharing options...
Alkorahil Posted July 21, 2011 Share Posted July 21, 2011 When you first start the truck, look at the switches to the left of the steering wheel. Below the mirror control next to the cruise control switch is the switch for transmission power control. When you start the truck up, does the light on the switch flash about 5 times? If it is flashing that indicates an error detected in the transmission by the transmssion control module. The FSM tells you how to decode the errors. Is your fluid level correct? Check the transmission dipstick with the vehicle in park and running after a good drive so that the vehicle transmission is good and warmed up. Keep in mind that too much fluid is as bad as too little. Does it smell burn or is it black in color? Does it shift into 2 and 1 and drive just fine? However, I think though that you are looking at the release solenoid in the valve body is out or the overdrive gear in the transmission is worn out. Link to comment Share on other sites More sharing options...
jwmyers23 Posted July 22, 2011 Author Share Posted July 22, 2011 Ok started her up and this is what I got. http://youtu.be/8f-nBDZjGZY Link to comment Share on other sites More sharing options...
adamzan Posted July 22, 2011 Share Posted July 22, 2011 This section of the fsm shows you how to decode the blinks http://www.nicoclub.com/FSM/pathfinder/1995_Pathfinder/at.pdf Yours the 1st flicker is longer which according to that manual says it has something to do with the revolution sensor. Link to comment Share on other sites More sharing options...
jwmyers23 Posted July 22, 2011 Author Share Posted July 22, 2011 (edited) ok found out what is wrong but not sure how to fix it. I'm not sure what I'm even looking for. Edited July 22, 2011 by jwmyers23 Link to comment Share on other sites More sharing options...
jwmyers23 Posted August 5, 2011 Author Share Posted August 5, 2011 Hooked pathy up to neighbors code reader. It says there's a selnoid out in the trans. I forget what it said it was. I also found out that you shouldn't weld on the exhaust with the o2 sensor in (OOPS). Link to comment Share on other sites More sharing options...
