Looking for steel wheels for a '91
Ink Ming
SEARCH! :P
I'd go with a 15x7 or 15x8 [not sure about your current tire size, I work on XXX * XXX RXX. 6 on 5.5 bolt circle with about 4.75 BS I think... less BS will make the wheels stick out a bit and give it a wider stance but then you run the risk of rubbing. This has been talked about a lot, search for backspacing... I'm not sure if the above number is right.
If you don't mind spraying..I just took my "stockies" off and and now runnin some black (chrome painted over) 15x8's with 255/70/15's..gawd i'm loving it! I will sellmine cheap....r u in California? sssh
  • 5 weeks later...
