seized slide pin
wilson
I have a seized slide pin on the the passenger rear wheel. it is the top pin and is part my off. any suggestion other than pb blaster and beating the piss out off it? Ive also taken the rubber plug out of the inner side and have been shooting pb blaster n there as well.
Heat... When I had a froze pin (hell it was even a top one!) I used a torch with a low flame, a small pry bar and a small hammer to get it moving. Once it was out I wire wheeled it, cleaned the caliper out with a dremmel and lubes everything up nice with some Bendix brake lube.
That is really weird. I just came in from doing my rear brakes and rotors. Guess what, I had a seized upper slide pin on the rear passenger caliper too! I just beat on it with a deadblow hammer and then worked it back and forth...I do a better job on it when the warmer weather arrives. Good luck with it!
