Alternator bearings going?
lint
'95 SE with ~120k miles. Belt tension is good and the belts while a couple years old, have ~15k miles on them.
Ever since the recent cold, when I'm idling, and I add a load by turning on the lights, or fan I hear a squeal that sounds like a bad bearing.
I noticed that when I remove the load the squeal goes away. I'll try dressing the belts tomorrow. Do you think the alternator bearings or alternator is going?
Weather is getting really nasty here, if it is the alty, how long do you think I've got? The output is a steady 14.4v.
Cheers,
d
