Where did my Bright Lites go?
1987Bama
Got in my Pathfinder tonight to go to work,flicked my lites and no Bright lights.They worked fine yesterday when I parked it.
My dims are fine,just no Bright ligts.I am at work and it will be tomorrow before I can check,just wanting to see if anyone might know where to look.
Maybe the brights and dims on 2 seperate fuses?
I had both my brights (bulbs) fail at the same time once. Don't rule that out....
spot on!! bulbs it was..I even lost a low beam last night on way home and was running one light only.
Always check the simple things first i guess.
thanks guys
Tell me about it. No hi beams does suck. I had the relay issue causing one hi beam to not function right. I fixed it by buying the brightest bulbs Napa had and using foglights. No need for hi beams! I even got flashed when just using lo's cause they were so damn bright!
