VegasPathfinder Posted December 2, 2010 Share Posted December 2, 2010 I had my clutch just replaced and now the drive shaft is rubbing inside the sleeve on the tail of the transfer case. It is the area where the driveshaft slides into the tail of the transfer case. Has anyone had that problem and what is the fix? Thanks! Link to comment Share on other sites More sharing options...
MY1PATH Posted December 2, 2010 Share Posted December 2, 2010 Its not on there very tight so usually you can wiggle the cover a little bit untill you find a position that is silent. Link to comment Share on other sites More sharing options...
GrimGreg Posted December 2, 2010 Share Posted December 2, 2010 Yeah, find the point it is rubbing and try bending it away a little at that point. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted December 2, 2010 Share Posted December 2, 2010 In other words.. either a BFH or a BFS (big freakin screwdriver) Link to comment Share on other sites More sharing options...
MY1PATH Posted December 2, 2010 Share Posted December 2, 2010 In other words.. either a BFH or a BFS (big freakin screwdriver) actually if your not a wimp you can repositon it with you hands. Link to comment Share on other sites More sharing options...
VegasPathfinder Posted December 2, 2010 Author Share Posted December 2, 2010 (edited) Ok so if I get under there I can bend it a bit? Is there any chance of damaging the seal or bearing if I use a BFH on it? Edited December 2, 2010 by VegasPathfinder Link to comment Share on other sites More sharing options...
nunya Posted December 2, 2010 Share Posted December 2, 2010 you wount need to haul off and swing full boar at it... just some love taps Link to comment Share on other sites More sharing options...
VegasPathfinder Posted December 5, 2010 Author Share Posted December 5, 2010 you wount need to haul off and swing full boar at it... just some love taps OK I bent it up a bit and so far so good! Thanks for the replies! Link to comment Share on other sites More sharing options...
