headpeace Posted September 16, 2010 Share Posted September 16, 2010 Hey all, I just saw the above mentioned tranny on CL close to my house for $150, will it fit? Would I have to use a different ECU? It just got me thinking that if it was an easy swap that seems like a good price for a manual, or am I Link to comment Share on other sites More sharing options...
nunya Posted September 16, 2010 Share Posted September 16, 2010 You won't need a different ecu as your basicly only eliminating the one for the auto and a Manuel is well... Manuel. But be warned there is more than just "unbolt automatic, bolt in 5 speed, drive". A couple people here have swapped and one of them will proably chime in shortly to point you to their swap threads to help give you a better idea of what's involved. And I 'think' they are the same 5 speeds through the wd21-d21 range are the same as long as from one with the same amount of powered axles. But don't hold me to that... Link to comment Share on other sites More sharing options...
MY1PATH Posted September 16, 2010 Share Posted September 16, 2010 the gear ratios inside are slightly differant but everything else on the v6 tranny was is the same. Link to comment Share on other sites More sharing options...
Kingman Posted September 16, 2010 Share Posted September 16, 2010 Yeah. Ratios are a *little* different but it's all the same. Link to comment Share on other sites More sharing options...
GrimGreg Posted September 20, 2010 Share Posted September 20, 2010 If it was from a 4cyl it won't work. Link to comment Share on other sites More sharing options...
