stmpjmpr Posted August 18, 2010 Share Posted August 18, 2010 Where and what should I do?? I have a stock pathy, I would like to run 34-36s to start off with. I like hardcore wheeling.I went to my local offroad shop and they said I couldn't do suspention lift on my 89 pathy where do I look? Also what's the cheapest way to (fix) / upgrade my axles/t-case ect? I think I'll stick with the six cyl. So what's best drivetrain combo for extreme wheeling? (Building a trailer queen) also was thinkiong of welding the rear and selcctable in front good Idea or not? Thanks for any input my name is Russ from washington. Link to comment Share on other sites More sharing options...
KovemaN Posted August 18, 2010 Share Posted August 18, 2010 Ditch the IFS and put a D44 or D60 up front and put longer arms on the rear. The rear Nissan axle and t-case are strong enough for 35s. Oh yeah, welcome to the site. Link to comment Share on other sites More sharing options...
BoneZ Posted August 18, 2010 Share Posted August 18, 2010 Swap in a dana 44 in the front. 86-91 waggy axles avoid vacume disconnect ones, or early bronco axles are about the right width and they are drive side drop. You could go with a 60 like posted above but if you are keeping the v6 it weighs to much for the engine. If you have a manual tranny it will be fine if you have a auto swap it for a manual or swap out the drive train to something with a stronger auto. Then to keep your power ether put 4.88 gears in the front dana 44 and get xterra 4.9 gears that will fit in your rear. or buy 5.13 for front and rear. That is just my opinion. Link to comment Share on other sites More sharing options...
stmpjmpr Posted August 19, 2010 Author Share Posted August 19, 2010 Swap in a dana 44 in the front. 86-91 waggy axles avoid vacume disconnect ones, or early bronco axles are about the right width and they are drive side drop. You could go with a 60 like posted above but if you are keeping the v6 it weighs to much for the engine. If you have a manual tranny it will be fine if you have a auto swap it for a manual or swap out the drive train to something with a stronger auto. Then to keep your power ether put 4.88 gears in the front dana 44 and get xterra 4.9 gears that will fit in your rear. or buy 5.13 for front and rear. That is just my opinion. Link to comment Share on other sites More sharing options...
stmpjmpr Posted August 20, 2010 Author Share Posted August 20, 2010 (edited) Well that is not a response lol I ment to say thanks for the in put. So I should find a d44 for the front out of late 80s cherokee or anoutherwords xj ? What is the rear on 89 pathy? Is c-clip or non c-clip? And can it handle 4.88s with locker and rock crawling or is 5.13 better? I have manual tranny aswell. Edited August 20, 2010 by stmpjmpr Link to comment Share on other sites More sharing options...
pathblazin420 Posted August 26, 2010 Share Posted August 26, 2010 the off road shop u went to must not know what they are talking about. they just lost a customer to there stupidity Link to comment Share on other sites More sharing options...
GrimGreg Posted September 23, 2010 Share Posted September 23, 2010 the off road shop u went to must not know what they are talking about. they just lost a customer to there stupidity Most of them have no clue about Nissans, and the few that will work on Nissans tend to mess them up. Link to comment Share on other sites More sharing options...
BoneZ Posted September 23, 2010 Share Posted September 23, 2010 Well that is not a response lol I ment to say thanks for the in put. So I should find a d44 for the front out of late 80s cherokee or anoutherwords xj ? What is the rear on 89 pathy? Is c-clip or non c-clip? And can it handle 4.88s with locker and rock crawling or is 5.13 better? I have manual tranny aswell. You want the axle from a Jeep Grand Wagoneer not a cherokee xj, or ZJ, the full size type ones. and the gearing thing really depends on your driving style. Link to comment Share on other sites More sharing options...
