shooter Posted August 13, 2010 Share Posted August 13, 2010 How do the factory shocks work? What actually happens when you switch from touring to sport? Link to comment Share on other sites More sharing options...
nige Posted August 13, 2010 Share Posted August 13, 2010 sport is supposed to increase the "stiffness" Link to comment Share on other sites More sharing options...
KovemaN Posted August 13, 2010 Share Posted August 13, 2010 There is a magnetic fluid in the shocks and when you switch it to "Sport" the viscosity of the fluid is increased making the shock stiffer like Nige said. Link to comment Share on other sites More sharing options...
edicer2 Posted August 13, 2010 Share Posted August 13, 2010 most wd21s by now that have them are probably worn out unless they were replaced. So you might not be able to tell a difference anymore. Link to comment Share on other sites More sharing options...
bigred07 Posted August 13, 2010 Share Posted August 13, 2010 Yeah they get stiffer in sport. My front ones had been replaced but my back ones still work and there is still a noticable difference. Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 15, 2010 Share Posted August 15, 2010 I have them in the 94 I bought, didn't think they worked cause the light in the switch was bad, but when I tried each setting and pushed down in the cargo area with the hatch open you can definitely see a difference, on sport you can't push the truck down at all !! on comfort (some say touring) you can push the body down, also noticeable if you push near the roof side to side Link to comment Share on other sites More sharing options...
