1987Bama Posted June 25, 2010 Share Posted June 25, 2010 I think my 87 idles to high.on cold start and even once it gets moderately warm,its still 1700 rpm.If i turn on the ac,it will drop down to 1500.I also noticed once i drive it and say I go through a drive-thru,with it in gear,ac on it idles nice and low.real smoothe.is this inside the normal idling at COLD start? Link to comment Share on other sites More sharing options...
MY1PATH Posted June 25, 2010 Share Posted June 25, 2010 (edited) there is a screw that ajusts your cold idle speed. It points skyward. on your thottle cam. find my TBI thread for pictures and more info. cold idle should be 1200-1500 normal idle should be 750-900, 1000 if your need a little help with emissions. It should not slow down w/ A/C also check my thread for how the the Idle up ajuster for A/C and electrical draw. http://www.nissanpathfinders.net/forum/index.php?showtopic=23251&st=0&p=416253&fromsearch=1&&do=findComment&comment=416253 Edited June 25, 2010 by MY1PATH Link to comment Share on other sites More sharing options...
adamzan Posted June 25, 2010 Share Posted June 25, 2010 750 1 Link to comment Share on other sites More sharing options...
1987Bama Posted June 25, 2010 Author Share Posted June 25, 2010 750 750 is what? cold idle? Link to comment Share on other sites More sharing options...
silverton Posted June 25, 2010 Share Posted June 25, 2010 I think you skipped MY1PATH's post... Link to comment Share on other sites More sharing options...
Kingman Posted June 25, 2010 Share Posted June 25, 2010 Nissan states warm idle to be between 750-850 with no accessories on, it should say it on a placard under your hood as well as timing marks. Try adjusting it according to MY1PATH's post. Link to comment Share on other sites More sharing options...
1987Bama Posted June 26, 2010 Author Share Posted June 26, 2010 I think you skipped MY1PATH's post... No,I read his post. The other guy just threw out 750.I wante dto know if that was 750 rpm or 750 mph?..lol Link to comment Share on other sites More sharing options...
adamzan Posted June 26, 2010 Share Posted June 26, 2010 I'm pretty sure its supposed to be at 750 rpm warmed up idle. At least that is what all mine idle at and I've never messed with them. It goes up like 100 rpm with the a/c initially then falls down back to normal Link to comment Share on other sites More sharing options...
1987Bama Posted June 26, 2010 Author Share Posted June 26, 2010 when u say normal idle once warmed,is that in Park or in Gear?I am assuming Park? Thanks guys Pathy may not be as off as I thought Link to comment Share on other sites More sharing options...
bigsyke Posted July 25, 2010 Share Posted July 25, 2010 Id like to know too, my idle is 1200rpms in park, 400 in drive. Link to comment Share on other sites More sharing options...
Kingman Posted July 25, 2010 Share Posted July 25, 2010 It should be set when the engine is at operating temperature, in drive. Put a few bricks or something in front of the tires so it doesn't drive away from you. That last part is from experience by the way... Link to comment Share on other sites More sharing options...
silverton Posted July 25, 2010 Share Posted July 25, 2010 Idle has always meant out of gear. Neutral. Park. Whatever. It should be around 800rpm when it's fully warmed up. 1200'ish on a cold start just to get stuff moving around. When I put mine into gear, the rpm barely changes, MAYBE down to 600. Link to comment Share on other sites More sharing options...
silverton Posted July 25, 2010 Share Posted July 25, 2010 Kingman. You really put your truck in gear and got out of it to adjust the idle? Link to comment Share on other sites More sharing options...
Kingman Posted July 25, 2010 Share Posted July 25, 2010 I was always taught to set idle wherever the engine will be running at it's lowest, which is in gear. Yes it was a long time ago...runaway truck... Link to comment Share on other sites More sharing options...
bigsyke Posted July 26, 2010 Share Posted July 26, 2010 If I set my idle in gear to 700 rpms, the park idle is around 1500rpms. I have my TPS, Timing all set correctly. Does the FSM say anything for setting idle and tps? heck even timing? Link to comment Share on other sites More sharing options...
silverton Posted July 26, 2010 Share Posted July 26, 2010 I've always been taught to set the idle RPM at, well, idle not in a gear. the ECU should take care of the rest from there. Link to comment Share on other sites More sharing options...
87pathy Posted July 26, 2010 Share Posted July 26, 2010 should be under 800 for emissions test. Link to comment Share on other sites More sharing options...
Kingman Posted July 26, 2010 Share Posted July 26, 2010 Emissions limit is 1100. Link to comment Share on other sites More sharing options...
bigsyke Posted July 30, 2010 Share Posted July 30, 2010 (edited) Emissions limit is 1100. Correct Idle speed is 700 rpms in D found on the card under my hood. I cant even get anywhere close to that without the Park idle being around 2000rpms. Ive capped everything, and replaced almost all gaskets on the IM/TB, new timing and everything (o2's ect) I cant get my TPS sensor within spec while the idle in Drive is 700rpms. THe TPS is around 0.80v+ at that point. The distributor is all the way retarded (which is still advanced with the timing gun) I have to have my D idle at 300rpms just to keep things within spec, and the Park/N idle is still above 1k. Edited July 30, 2010 by bigsyke Link to comment Share on other sites More sharing options...
