Steering Wheel Shake
vmodi
Hi folks:
Driving my R50 above 60mph on the highway makes my steering wheel shake left/right quite a bit. I recently got new shocks and struts so I know its not that. It is not swaying, the ride is very smooth. Its just the steering shake. Painful for my wife when she drives for a bit.
Also, the steering lock is not working, not sure if it is related (doesn't sound like it) but throwing it out there.
I don't intend to fix this myself, don't really have any shop equipment or expertise. However when I take it to a mechanic (most likely on Monday) what should I expect to pay? Also, it would be good to know what it could be to talk sensibly to the mechanic. :)
Thanks!
Would an off alignment cause this at all?
No, that would cause a pull to the left or right. The list of things Adam pointed out would be possible causes. A bent rim, or out of balance tire would be the main cause for a shimmy/shake at a certain speed. One other part/cause he left out is worn wheel bearings.
normally a vibration felt thru the steering wheel indicates a problem in the front, could be anything previously listed, a vibration felt thru the seat usually is from the rear
I 2nd that
rear wheel bearings or the brakes are weird :shrug:
