New Signals :)
Manifesto
ALRIGHTY, so after being pulled over the same day I started driving this beast for not having functional signal lights up front,
I picked up some nifty LED markers from Part Source for $10 each and mounted them up.
A nice little improvement :)
Install was pretty smooth. Drilled 2 holes in the steel plate for mounting, 3" apart.
Used my eyeball to drill the first hole, then once I had the light mounted with one screw, I used a sharpee to mark the 2nd.
I utilized an original hole already there to feed the wires through (was about 3/16")
As for wiring, I just cut off the ground connectors and spliced them entirely into the factory harness
I couldn't find the exact ones I used, but they're pretty similar to these
The LED's are way brighter than the original incandescent light bulbs that were there before :)
Edited by Manifesto
