Rock Sliders
beastpath
hmmmm. so for those guys who might have so much rust they need another frame, getting a HB frame might be an interesting solution. It would give you a BL right off the bat.
And a more work modifying the mounts to work with the PF body ;)
The front 3 body mounts are in the same location on both (2 front, 2 A pillar, 2 B pillar), from there they are completely different. The HB has 2 rear body mounts and 4 bed mounts, where the Pathfinder has mounts at the 2 C pillar and 2 at the rear. Also, wheel bases are different, so you would have a good bit of work in changing that to match. It would be much easier to put a HB cab on a Pathy frame.
Edited by GrimGreg
