Addz Posted February 22, 2010 Share Posted February 22, 2010 The power steering fluid is pissing out of my 93 Terrano. Not positive of the exact location, but the pump is covered in fluid. Checked the hoses retightened the clamps and no luck stopping the flow Before i spring for a new/recon pump wondering what usually goes wrong with them, seals or anything that i can fix. Had a good result with the last question i asked on here so here goes again thx Addz Link to comment Share on other sites More sharing options...
DavefromOZ Posted February 22, 2010 Share Posted February 22, 2010 Not sure mate, but I have a similar problem, I just keep degreasing mine and topping it up. You just reminded me to see if a mate has one out of his parts bus still. Link to comment Share on other sites More sharing options...
PATHRIDER Posted February 22, 2010 Share Posted February 22, 2010 The power steering fluid is pissing out of my 93 Terrano. Not positive of the exact location, but the pump is covered in fluid. Checked the hoses retightened the clamps and no luck stopping the flow Before i spring for a new/recon pump wondering what usually goes wrong with them, seals or anything that i can fix. Had a good result with the last question i asked on here so here goes again thx Addz You might wanna try replacing the return hose and using new clamps Link to comment Share on other sites More sharing options...
GrimGreg Posted February 22, 2010 Share Posted February 22, 2010 When mine (88) started leaking it was a pinhole leak in the high pressure hose. I cut out the bad section and reconnected the hose witha dual barb fiting and some clamps. It's been fine since. Link to comment Share on other sites More sharing options...
