Dasanii19 Posted February 7, 2010 Share Posted February 7, 2010 (edited) I was about to take out my oil filter when I noticed oil all over my engine oil cooler. I cant see where its particularly leaking from, the hose clamps look good and the gaskets looks clean. Any ideas? Ill post a picture in a minute. By the way, this is on my 2003 Nissan pathfinder V6 3.5 4x4 . First post here, thanks!! Hopefully this is a clue to why im loosing some oil between oil changes. Edited February 7, 2010 by Dasanii19 Link to comment Share on other sites More sharing options...
01silvapathy Posted February 7, 2010 Share Posted February 7, 2010 Just try and use the search function....I started this same topic less than a month ago http://www.nissanpathfinders.net/forum/index.php?showtopic=25159 Just dont let the dealership rip you off, Like I was unfortunately. There is no diff between 4x4 and 2x4, rather between the manual trans and auto. The job should cost under 250 bucks, if its indeed the oil cooler O-Rings not the oil cooler itself. Apparently even the tech at nissan said he had never seen a cracked oil cooler its always the rubber O-Rings that need to be replaced. Link to comment Share on other sites More sharing options...
Dasanii19 Posted February 7, 2010 Author Share Posted February 7, 2010 (edited) Just try and use the search function....I started this same topic less than a month ago http://www.nissanpathfinders.net/forum/index.php?showtopic=25159 Just dont let the dealership rip you off, Like I was unfortunately. There is no diff between 4x4 and 2x4, rather between the manual trans and auto. The job should cost under 250 bucks, if its indeed the oil cooler O-Rings not the oil cooler itself. Apparently even the tech at Nissan said he had never seen a cracked oil cooler its always the rubber O-Rings that need to be replaced. Thanks man. I actually did do a search, not sure why I didn't see your thread. Would anyone happen to know a part # for these O rings? Also, would this be the culprit to my oil consumption? Edited February 7, 2010 by Dasanii19 Link to comment Share on other sites More sharing options...
Dasanii19 Posted February 7, 2010 Author Share Posted February 7, 2010 Can someone explain how to get the O rings out? Is it the bolt on the oil cooler between the two hoses to comes out? Link to comment Share on other sites More sharing options...
Dasanii19 Posted February 7, 2010 Author Share Posted February 7, 2010 Nevermind,I found the fix here: http://www.nissanforums.com/pathfinder/142468-2001-pathfinder-odd-oil-leak-pics.html Link to comment Share on other sites More sharing options...
Alkorahil Posted February 9, 2010 Share Posted February 9, 2010 Would anyone happen to know a part # for these O rings? Part Number: 21304-17F20 Fits all R50 with 3.5L engine. Also, would this be the culprit to my oil consumption? Based on the pics, more than likely! Link to comment Share on other sites More sharing options...
TooQForYou Posted February 10, 2010 Share Posted February 10, 2010 Yeah, that sounds like what the problem is. Happened to my Q last year. If you could replace it yourself or find a friend that can do it for you, that would be the way to go. $250 is just ridiculous for replacing a few o-rings. Luckily my father is a mechanic and did it for me. Didn't take him long, so it should be an easy fix. Link to comment Share on other sites More sharing options...
wjodea1 Posted May 14, 2012 Share Posted May 14, 2012 How do you get at the bolt? Its so damn crammed in there! Any recommendations are appreciated. Link to comment Share on other sites More sharing options...
