Engine Oil Cooler Leaking Oil?
Dasanii19
I was about to take out my oil filter when I noticed oil all over my engine oil cooler. I cant see where its particularly leaking from, the hose clamps look good and the gaskets looks clean. Any ideas? Ill post a picture in a minute. By the way, this is on my 2003 Nissan pathfinder V6 3.5 4x4 .
First post here, thanks!! Hopefully this is a clue to why im loosing some oil between oil changes.
Edited by Dasanii19
Just try and use the search function....I started this same topic less than a month ago ;)
http://www.nissanpathfinders.net/forum/index.php?showtopic=25159
Just dont let the dealership rip you off, Like I was unfortunately. There is no diff between 4x4 and 2x4, rather between the manual trans and auto. The job should cost under 250 bucks, if its indeed the oil cooler O-Rings not the oil cooler itself. Apparently even the tech at nissan said he had never seen a cracked oil cooler its always the rubber O-Rings that need to be replaced.
Just dont let the dealership rip you off, Like I was unfortunately. There is no diff between 4x4 and 2x4, rather between the manual trans and auto. The job should cost under 250 bucks, if its indeed the oil cooler O-Rings not the oil cooler itself. Apparently even the tech at Nissan said he had never seen a cracked oil cooler its always the rubber O-Rings that need to be replaced.
Thanks man. I actually did do a search, not sure why I didn't see your thread. Would anyone happen to know a part # for these O rings? Also, would this be the culprit to my oil consumption?
Edited by Dasanii19
Part Number: 21304-17F20
Fits all R50 with 3.5L engine.
Based on the pics, more than likely!
Yeah, that sounds like what the problem is. Happened to my Q last year.
If you could replace it yourself or find a friend that can do it for you, that would be the way to go. $250 is just ridiculous for replacing a few o-rings. Luckily my father is a mechanic and did it for me. Didn't take him long, so it should be an easy fix.
  • 2 years later...
