Wheel Offset?
Channel595
You are wrong. flat out wrong. go look at your stock legos, they are not 3 and 3/4 backspacing. no fawking way.
just take a tape measure and eye it, and you will see it is no where near that, but is more like and inch or inch and a quarter more than 3.75
Very annoying that the FSM doesn't show the backspacing, but it does state the offset for the legos to be 25mm or .98" and for the steelies 30mm or 1.18".
So, the Legos are a 7 inch width rim. With an offset nearing an inch. so the centerline on the legos would come to 3.5 inches. Add the offset to that, making it 4.5 inches of backspacing.
The Steelies are a 6 inch wide rim. With an offset a little more than an inch. so the centerline on the steelies would be 3 inches. Add the offset to that, making it 4.20 inches of backspacing.
Both PROVING my point about them not being 3.75 inches backspacing.
