AeroSync Posted December 9, 2009 Share Posted December 9, 2009 (edited) I replaced the brake pads (4 wheel discs) on my Pathfinder a few weeks ago, and whenever I press the brakes, it feels like if they were floating. For example, I can be going 25 MPH, and slam on the brakes, and it takes a good long distance to stop, about 5 yards, and while doing this, my brake pedal is on the floor. What can be causing this, as I do not feel safe driving around with weird brakes? I can press the brake pedal for about 1" before it actually starts to slow down. Edited December 9, 2009 by AeroSync Link to comment Share on other sites More sharing options...
Kingman Posted December 9, 2009 Share Posted December 9, 2009 What parts exactly did you replace? Saying you replaced "the brakes" doesn't mean a thing. It could be your brake booster loosing vacuum, your brake booster check valve, your brake lines might have air in them, which falls under the category of what you replaced... Link to comment Share on other sites More sharing options...
Nismojunky Posted December 9, 2009 Share Posted December 9, 2009 air in your system keep bleeding the system untill you have your brakes back let them gravuty bleed for a bit to follow the fsm as to the order to bleed them and if its drums they could need adjusting Link to comment Share on other sites More sharing options...
AeroSync Posted December 9, 2009 Author Share Posted December 9, 2009 (edited) Forgot to say, I replaced the brake pads. It has 4 wheel disc brakes. Thank you Nismojunky, I will see about that. Edited December 9, 2009 by AeroSync Link to comment Share on other sites More sharing options...
elnino Posted December 9, 2009 Share Posted December 9, 2009 we changed the pads and bleed the system...it was fine the first days...but now its acting up..... is it a nissan thing? Link to comment Share on other sites More sharing options...
adamzan Posted December 9, 2009 Share Posted December 9, 2009 Try bleeding the proportioning valve again, if you didn't already do it a couple times. Its a bitch to bleed. Link to comment Share on other sites More sharing options...
elnino Posted December 9, 2009 Share Posted December 9, 2009 Try bleeding the proportioning valve again, if you didn't already do it a couple times. Its a bitch to bleed. can you explain ? Link to comment Share on other sites More sharing options...
Precise1 Posted December 9, 2009 Share Posted December 9, 2009 Towards the rear of the truck on the passenger side inside frame rail is the ABS unit, make sure to bleed that as well. I don't know about the proportioning valve as I do not have 4 wheel disk... B Link to comment Share on other sites More sharing options...
adamzan Posted December 10, 2009 Share Posted December 10, 2009 Crap. I meant the abs valve. Sorry! Link to comment Share on other sites More sharing options...
