Shrockworks Rock Sliders
packie88
Just got off the phone with shrockworks and it so happens that they make sliders for the 89-95 pathfinder. they are the same cost as the xterra ones ($379) and they are weld on. They are not listed on the website but if you call they have. i talked with jim i think it was. Just another option. and figure i would let you all know
do these sliders take a 3" body lift into account? or will they have a huge gap between the rocker and the slider?
they come with the legs de-tached so you can rotate them upwards before welding to compensate for BL
theres an option to add a 3 inch bodylift on it. and i know right 400 is kinda insane. and i looked into the trail gear one and im considering em the only problem is the short ones are a little short and the long ones are to long.
The local steel place sells 2" .120 wall square tube for about $5/foot (at least last time I bought any, and steel was high then). At that price I could make a set for $100 or even a little less for material cost.
As with anything else, most of what you are paying for is the labor cost.
