pathydaddy Posted October 24, 2009 Share Posted October 24, 2009 how many gallons does the factory tank hold in my 95 pathy.. dunno what model it is but its power mirrors windows locks and sun roof if that helps at all... im trying to see if my theories about my milage are correct Link to comment Share on other sites More sharing options...
beastpath Posted October 24, 2009 Share Posted October 24, 2009 21 gallons Link to comment Share on other sites More sharing options...
pathydaddy Posted October 24, 2009 Author Share Posted October 24, 2009 21 gallons damn 200 miles to a full tank... still cant figure out why im getting such poor mileage...any ideas Link to comment Share on other sites More sharing options...
Formerly_94PathyMan Posted October 24, 2009 Share Posted October 24, 2009 (edited) Do you have a gas smell inside and outside the car? If so it could be your Evap canister. Have you had your injectors checked? MAF? O2 sensor? Fuel filter? Those are all that come to mind at the moment. Edited October 24, 2009 by 94Pathyman Link to comment Share on other sites More sharing options...
pathydaddy Posted October 24, 2009 Author Share Posted October 24, 2009 Do you have a gas smell inside and outside the car? If so it could be your Evap canister. Have you had your injectors checked? MAF? O2 sensor? Fuel filter? Those are all that come to mind at the moment. no gas smell.. im tight on funds and having a shop check injectors and maf are kinda out of the picture.. i was planning on doing the fuel filter sunday any other ideas? Link to comment Share on other sites More sharing options...
Soccerstudd5 Posted October 24, 2009 Share Posted October 24, 2009 damn 200 miles to a full tank... still cant figure out why im getting such poor mileage...any ideas Check the mileage based on how many gallons you put back in. Some people have said that there gage is a little off and they really have couple more gallons after hitting E. Either way... I only seem to get 15 mpg out of my 94. There was a post of someone asking why they got bad mileage, lots of good suggestions in there.... a little search should find it easily. Link to comment Share on other sites More sharing options...
beastpath Posted October 24, 2009 Share Posted October 24, 2009 you can check your codes on the ECU yourself. The codes/how to are pinned in the garage how to section. when was the last time you had a tune up: plugs, wires, cap, rotor? my fouled plugs were killing the mileage. Link to comment Share on other sites More sharing options...
Tungsten Posted October 26, 2009 Share Posted October 26, 2009 damn 200 miles to a full tank... still cant figure out why im getting such poor mileage...any ideas From my personal experience, any leak in the manifold or anywhere in the exhaust before the o2 sensor will cause your mpg to drop like a stone. Also make sure your coolant temp sensor is good. Those like to fail but for some reason mine is fine. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted October 26, 2009 Share Posted October 26, 2009 From my personal experience, any leak in the manifold or anywhere in the exhaust before the o2 sensor will cause your mpg to drop like a stone. Also make sure your coolant temp sensor is good. Those like to fail but for some reason mine is fine. That explains alot! Link to comment Share on other sites More sharing options...
GrimGreg Posted October 27, 2009 Share Posted October 27, 2009 Have you checked that your speedo/odo are accurate? If you are running a larger tire than came on the truck stock then it will read less milage on the odo. Link to comment Share on other sites More sharing options...
Precise1 Posted October 27, 2009 Share Posted October 27, 2009 Good advice. damn 200 miles to a full tank... still cant figure out why im getting such poor mileage...any ideas Check the mileage based on how many gallons you put back in. This. I have never put more than 18 gallons into the fuel tank at once in 5 years so pay no attention the the capacity, but calculate by the useage. B Link to comment Share on other sites More sharing options...
