tekazgtr1984 Posted October 22, 2009 Share Posted October 22, 2009 Does anyone know how to check why running lights don't work? Mine have been functioning intermittently over the last while (i.e. I'll fire up the truck and they'll be on, go for a short drive, shut off the truck. When I turn it back on, the running lights don't work.) and I'd like to know how I can permanently remedy this issue. Cheers! Link to comment Share on other sites More sharing options...
Silverbullet Posted October 22, 2009 Share Posted October 22, 2009 I actually have the same problem, only mine dont work at all. One night my drivers headlight burnt out(or i thought it did) so i checked the bulb and its fine. My daytimes dont come on and my drivers head light doesnt work at all, but my passenger one works on low and high beam. Also the high beam indicator light in the dash comes on even on the low beam setting, but not when i just turn my marker lights on. Anyone have any ideas? Link to comment Share on other sites More sharing options...
XPLORx4 Posted October 22, 2009 Share Posted October 22, 2009 I actually have the same problem, only mine dont work at all. One night my drivers headlight burnt out(or i thought it did) so i checked the bulb and its fine. My daytimes dont come on and my drivers head light doesnt work at all, but my passenger one works on low and high beam. Also the high beam indicator light in the dash comes on even on the low beam setting, but not when i just turn my marker lights on. Anyone have any ideas? How did you check the bulb? Did you swap it with the passenger-side headlamp bulb? Since your high-beam indicator comes on all the time, the problem may be the multifunction headlamp/turn signal switch. Link to comment Share on other sites More sharing options...
Silverbullet Posted October 24, 2009 Share Posted October 24, 2009 How did you check the bulb? Did you swap it with the passenger-side headlamp bulb? Since your high-beam indicator comes on all the time, the problem may be the multifunction headlamp/turn signal switch. Yes, I tried switching the bulbs and nothing changed. Good thing I have off road lights on my bumper lol. I just set it to the marker lights and drive with the off-road ones on. It looks very mean from the front. Link to comment Share on other sites More sharing options...
JUDGE Posted October 24, 2009 Share Posted October 24, 2009 You should both check the daytime running light module, it's behind the battery. Disconnect it, open it and check all solder welds. Mine was acting up and it turned out to be one small weld, easily fixed with a soldering pencil. HTH! Link to comment Share on other sites More sharing options...
adamzan Posted October 25, 2009 Share Posted October 25, 2009 You should both check the daytime running light module, it's behind the battery. Disconnect it, open it and check all solder welds. Mine was acting up and it turned out to be one small weld, easily fixed with a soldering pencil. HTH! Yes check this out. It was the same on my truck as well. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted November 4, 2009 Author Share Posted November 4, 2009 Yep, the DRL module was to blame. Damn welds... Anyhoo, problem solved and a new module is in! Link to comment Share on other sites More sharing options...
