Nismojunky Posted September 20, 2009 Share Posted September 20, 2009 hey guys my pathfinder has a problem, it seems to be misfireing and not burning all the fuel, its got new plugs wires cap as of june timming as of june and O2 as of january, what could cause this i checked for vacume leaks and there are none, im out of ideas Link to comment Share on other sites More sharing options...
nunya Posted September 20, 2009 Share Posted September 20, 2009 What brand tune up parts? Link to comment Share on other sites More sharing options...
Nismojunky Posted September 20, 2009 Author Share Posted September 20, 2009 nkg plugs and bosch wires cant remember cap and o2 was boush Link to comment Share on other sites More sharing options...
adamzan Posted September 20, 2009 Share Posted September 20, 2009 (edited) Are you absolutely sure they put the timing belt on right? The shop put my dads on off by one tooth, after you set the spark timing it ran ok but still "not right". Like you're talking about. Edited September 20, 2009 by adamzan Link to comment Share on other sites More sharing options...
94extreme Posted September 20, 2009 Share Posted September 20, 2009 ^^ timing is off or 02 sensor is kaput. Link to comment Share on other sites More sharing options...
Nismojunky Posted September 20, 2009 Author Share Posted September 20, 2009 we will have to check the timming we couldnt check it today the timming light wasnt getting a good reading the rpms were jumping every where apparently so ill get the mecanic to look it over im going to do a computer read out in the next few days Link to comment Share on other sites More sharing options...
adamzan Posted September 21, 2009 Share Posted September 21, 2009 If the timing is way off the belt is probably off a tooth. Also is the CEL on ? Link to comment Share on other sites More sharing options...
Nismojunky Posted September 21, 2009 Author Share Posted September 21, 2009 no cel light going tonight to get the timming checked Link to comment Share on other sites More sharing options...
adamzan Posted September 21, 2009 Share Posted September 21, 2009 I'll buy you a beer when you come up here if the timing is off. Link to comment Share on other sites More sharing options...
Nismojunky Posted September 22, 2009 Author Share Posted September 22, 2009 timming was fine and o2 is going to be tested tomorrow, we did discover that the distributer was off by a 16th of a inch we turned that and it has helped still running a lil rich tho probally the o2 Link to comment Share on other sites More sharing options...
adamzan Posted September 23, 2009 Share Posted September 23, 2009 So your tore it down and checked the timing belt and made sure it lined up right? Link to comment Share on other sites More sharing options...
