magregor Posted September 14, 2009 Share Posted September 14, 2009 Soooo, I put a set of R50 rims on my Pathy and just recently discovered this grinding noise in the front end when I turn the wheels sharp either way...I found out that the inside flange of the rim is rubbing on the tie rod end...Any recommended sites or ideas to bring the offset out about 1/2" or more? Link to comment Share on other sites More sharing options...
Toby Posted September 14, 2009 Share Posted September 14, 2009 Only thing I can think of is a spacer. I know the minitruck crowd has notched tie-rod ends but I doubt they make them for pathfinders. Especially considering the Off Road crowd drives them. Spacer might be your only option or to make your own notched tie-rod. Link to comment Share on other sites More sharing options...
adamzan Posted September 14, 2009 Share Posted September 14, 2009 Considering that you want to take this truck off road I wouldn't notch the tie rods. They can bend on their own without any help Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 14, 2009 Share Posted September 14, 2009 Check www.ruggedrocksoffroad.com. Link to comment Share on other sites More sharing options...
Toby Posted September 14, 2009 Share Posted September 14, 2009 Considering that you want to take this truck off road I wouldn't notch the tie rods. They can bend on their own without any help Yeah I wouldn't advise it at all. It's just what i've seen. It'd be too much pressure on it if it's notched and going off road. Link to comment Share on other sites More sharing options...
SteeevO Posted September 14, 2009 Share Posted September 14, 2009 These will fit http://ruggedrocksoffroad.com/trailgear-6x...ide-p-3665.html keep in mind that these are actually toyota spacers so the lugs on the spacers are a different thread than the nissan ones. Link to comment Share on other sites More sharing options...
