Fukinitupagain Posted August 13, 2009 Share Posted August 13, 2009 I need to know what the acual length of the rear AC coils. I have them but they are installed & I'd like to know what the length is with out the pressure. Thanks guys. Link to comment Share on other sites More sharing options...
FUELER Posted August 13, 2009 Share Posted August 13, 2009 flex your r50 very hard until one of the coils (on the decomressed side of course) is completely loose, and measure it yourself ! bada bing bada boom! Link to comment Share on other sites More sharing options...
Fukinitupagain Posted August 13, 2009 Author Share Posted August 13, 2009 flex your r50 very hard until one of the coils (on the decomressed side of course) is completely loose, and measure it yourself ! bada bing bada boom! I thought about doing that tomorrow Link to comment Share on other sites More sharing options...
XPLORx4 Posted August 14, 2009 Share Posted August 14, 2009 I thought about doing that tomorrow You'd need to partially detach the rear swaybar and unbolt the extended shock to allow an AC rear spring to fully extend. Link to comment Share on other sites More sharing options...
alexrex20 Posted August 14, 2009 Share Posted August 14, 2009 ^^^ True. Boston, you should've posted this thread 2 weeks ago, before i installed my AC coils. Link to comment Share on other sites More sharing options...
01silvapathy Posted August 14, 2009 Share Posted August 14, 2009 Boston? Just out of curiousity are you perhaps contemplating the use of F250 coils for use instead of the Spring spacers? Link to comment Share on other sites More sharing options...
Fukinitupagain Posted August 14, 2009 Author Share Posted August 14, 2009 Boston? Just out of curiousity are you perhaps contemplating the use of F250 coils for use instead of the Spring spacers? More than... AC's are 15.5" F250's are 18.75-19.25" so theoretically they will fit under there. Just gotta fab some @!*%e up... Link to comment Share on other sites More sharing options...
01silvapathy Posted August 14, 2009 Share Posted August 14, 2009 More than... AC's are 15.5" F250's are 18.75-19.25" so theoretically they will fit under there. Just gotta fab some @!*%e up... Wow that seems like they would work perfectly, if you could get them to fit in snugly, and stay in there, wonder how the ride would be with those? Link to comment Share on other sites More sharing options...
FUELER Posted August 14, 2009 Share Posted August 14, 2009 boston not runnin any sissy ass sway bars and u know this, man!!! Link to comment Share on other sites More sharing options...
FUELER Posted August 14, 2009 Share Posted August 14, 2009 Link to comment Share on other sites More sharing options...
FUELER Posted August 14, 2009 Share Posted August 14, 2009 (edited) if ur R50 hasnt done this than you havent flexed it hard enough mine has done this (on drivers side only) Edited August 14, 2009 by FUELER Link to comment Share on other sites More sharing options...
alexrex20 Posted August 14, 2009 Share Posted August 14, 2009 don't lie, fueler. you have OME rear shocks and they're not long enough to allow the rear coils to fall out. Link to comment Share on other sites More sharing options...
180sx Posted August 14, 2009 Share Posted August 14, 2009 did something get bent? And alex, if it wasn't long enough, it would do it all the time. If it's too long than it shouldn't do this. Jose Link to comment Share on other sites More sharing options...
alexrex20 Posted August 14, 2009 Share Posted August 14, 2009 no, shocks with too much travel (too long) will hyperextend the rear suspension, causing the rear coil to drop out. OME shocks will not do that. Link to comment Share on other sites More sharing options...
01silvapathy Posted August 14, 2009 Share Posted August 14, 2009 don't lie, fueler. you have OME rear shocks and they're not long enough to allow the rear coils to fall out. FAIL Link to comment Share on other sites More sharing options...
FUELER Posted August 14, 2009 Share Posted August 14, 2009 first of all i do not have OME shocks (which are monroes painted yellow and price doubled) i have flexed it out hard enough (i was stuck on very soft sand and it dug down gnarly) that the spring was loose and you could grab it and shake it around mine havent fallen out like pictured above, cause i have bumpstops still installed Link to comment Share on other sites More sharing options...
Fukinitupagain Posted August 14, 2009 Author Share Posted August 14, 2009 Yeah, I don't have bump stops or any sway bars & when its like that, well its inevitable that you'll shoot oout a coil at some point. All you do is either go really slowly back or forward until you come back down. Link to comment Share on other sites More sharing options...
Fukinitupagain Posted August 14, 2009 Author Share Posted August 14, 2009 Hey Adam, thats some old school pics of SystemF you got there. He's a local Texas boy (this was directed towards Alex & Andrew). here's another pic of his R50: Link to comment Share on other sites More sharing options...
01silvapathy Posted August 14, 2009 Share Posted August 14, 2009 if ur R50 hasnt done this than you havent flexed it hard enough mine has done this (on drivers side only) first of all i do not have OME shocks (which are monroes painted yellow and price doubled) i have flexed it out hard enough (i was stuck on very soft sand and it dug down gnarly) that the spring was loose and you could grab it and shake it around mine havent fallen out like pictured above, cause i have bumpstops still installed So which is it? Link to comment Share on other sites More sharing options...
180sx Posted August 15, 2009 Share Posted August 15, 2009 no, shocks with too much travel (too long) will hyperextend the rear suspension, causing the rear coil to drop out. OME shocks will not do that. Oops. My bad. Misread that one! Jose Link to comment Share on other sites More sharing options...
01silvapathy Posted August 15, 2009 Share Posted August 15, 2009 ur an idiot, kid. i said i got it loose but it didnt fall out. and you post a pic where it was loose and didnt fall out, and ask me "well which is it" 01silva pathy once again posting something he has no knowledge about im out No you very clearly posted a pic where the spring was doing more then just being "loose" I guess your qualifications of loose are 3in of gap. And wow, no knowlege? How can you say that we are talking about springs......go find a dirt lot and wheel....and im a idiot atleast i can type someones name right, brah Link to comment Share on other sites More sharing options...
Kingman Posted August 15, 2009 Share Posted August 15, 2009 Why are y'all arguing over something this stupid? All Boston was ask a simple question and it turned into another one of these arguments... Link to comment Share on other sites More sharing options...
01silvapathy Posted August 15, 2009 Share Posted August 15, 2009 Why are y'all arguing over something this stupid? All Boston was ask a simple question and it turned into another one of these arguments... Since this post added so much to this thread Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted August 15, 2009 Share Posted August 15, 2009 C'mon guys... That's just ridiculous. There's no need to resort to one-upping each other and acting like little kids. Smarten up. Why is it the R50 section is always so rife with tribulation? Link to comment Share on other sites More sharing options...
