92 pathfinder is puttering or missing
ac92pathfinder
of course when my 95 pathfinder messes up and the other car gonna mess up to which is a 92 pathfinder just started sputtering todayu and i can smell the exhaust is this an o2 sensor issue?
i dont have a check engine light on my dash. might be the fuel filter it would do a sluggish shake but when im at a traffic light it shakes to. in park it will miss alittle but it will also do alittle sputter in park when u rev the engine too. thanks for the reply
Yep, you don't need a CEL to check for error codes. The O2 sensor doesn't always trigger the CEL. You can also check the resistance of the O2 sensor, 1-1000 ohms IIRC.
Check/wiggle the wiring at the MAF, it can't hurt... :shrug:
