Crunching noise from back of truck
93 SE-V6 w/ 4-wheel disc brakes here.
After having my truck sitting for a week (not sure if that had something to do with it), I've noticed an occasional crunching noise coming from the rear end of my Pathy. I only hear when just moving forward from a stop and it seems to occur for a short period during each rear wheel rotation. I usually hear it for 3-4 rotations of the wheels then it disappears; and I don't think it's still there after speeding up because I can also feel the crunching as a slight vibration from the rear, and that disappears as well. It only occurs intermittently; I don't hear it every time I pull away from a stop, maybe only once every 3-4 times I pull away.
I took it to a tranny shop because I thought it was maybe a cracking U-joint, rear diff. problem, or maybe the rear axle; they took it for a few spins but also said it occurred so infrequently that they couldn't nail down the source of the noise or see a problem, although they did hear it.
Any ideas?
Thanks for any help!
