is it just me or is there somthing wrong?
another question for you guy's.... when i'm wheeling i will usually keep it in 2wd till i need 4wd if i put it in 4w hi in order to go up an incline i have to put it in first and even then it struggles. on any hill where there is any kind of loamy dirt or whoops i have to put it in 4 low and 1st otherwise i get stuck, and have to back down, if i put it in 4 low and second it does ok till i hit an incline and starts to bog and forces me to go back into 4 low 1st. is this common or could there be somthing wrong with my engine? i have replaced all the tune up items with all new, and adjusted the timing. it runs so much better now, but it's still being stubborn? any ideas?? :deadhorse: i know our little pathys are underpowered but this seems a little rediculus. thank you.
I think part of the problem is it seems our power band is a little higher than most - I know for me personally, my engine seems to have the most "oomph" around 3000-4000 rpm...
