Heating when AC is on
Jessyj
Scale/deposits on the inside of the cooling system, old coolant or even your fan clutch if it does it when you are stopped.
The AC condenser (heat exchanger) sits in front of the radiator. If your cooling system is already borderline capable, the added heat from the condenser could let the temperature climb.
Without better information, I start checking the entire cooling system. :shrug:
