2WD converted to 4WD
94 Pathy
Ok everyone.....I'm in the process of researching, but just wanted to throw this out and see if I can get some answers quicker then all the research...
I'm looking into a '94 2WD Pathy. If I swap my components from my frame decaying '94 4WD Pathy to this, what & how difficult is the conversion?
I'm thinking that your just adding the transfer case? Like I mentioned before, I'm just starting the research on the transferring 2WD to 4WD.
Thanks in advance for all your help & input!
the 2wd tranny will not bolt to the t-case, so your looking @ a tranny swap too.(I think that will be the hardest part)
tranny, t-case, front diff wheels hubs & possibly steering knuckles, gears if the 2wd is geared differant thatn your front diff....
electrical if you want the green light to work...
I think you've got all the parts you need, but it may be a lengthy project. I hope you have a freind or 2 to help out.
