Sliders
msavides
Well I just fabbed up my sliders and well they are quite heavy. The construction consists of 2 6 foot sections of 2x2 square stock at 3/16th Inch thick for each side. I still have to install them and paint them. I will post pics of the completed sliders pre install and post install later this week. The complete weight of just one slider is about 65 lbs. Puts me at about 130 pounds total weight.
How do others compare in weight?
Mark
Edited by msavides
As Promised here are the pics of the rock rails in progress. I will post pics of them installed after this weekend. Still have some grinding and more welding to do to them before they are ready for paint.
Here is a sample on how they are constructed.
Mark
... most ppl use a single 1.5 - 2" .250 wall DOM, i hope gas is cheep in your area.
I only drive it around town and wheeling so It won't bother me much. If it was my daily driver I would definitely have reconsidered it.
How thick are the mounting plates? I can't tell by the pictures but I personally wouldn't go thinner then 1/4".
every piece on metal in this design is 3/16 thick. the metal for the mounting plates is the same height as the frame and will be welded to the top and the bottom edges of the frame. I will be applying weld thru primer to the frame and the plates prior to welding to keep it from rusting in between them. I think it will be plenty strong since I am spreading the load across a large area of the frame
It is pretty much over engineered already.
Updated pic
I finished welding and grinding. and put the weld thru primer on the plates, and put bedliner on the topside of the rockrails. Next (after it dries I can weld them on the truck and finish bedlining the bottom.
why not? the frames no more than 1/8" maybe 3/16" at best, anything thicker is dead weight. there is such a thing as over engineering things
It doesn't matter how thick the frame is, your putting a load on the frame that it was never designed for. But as far as the mounting plates go, i'm more concerned about the short legs ripping off the mounting plates. I was only asking because the mounting plates looked quite thin in the pictures. It should be good with the 3/16" metal and hopefully you never slam the entire weight of the truck on one side. I do like the crossing leg design though :aok:
I guess we will see if they hold up. If they fail. I will go back to the redesign stage. My first indication that the plates my have been too thin was that they warped a little bit when I welded the cross pieces to them. Although I think the rosette welds in the 2 holes in each plate should help keep the plates from bending under stress. Time will tell, Now I will have to go find some rocks and see if I can bend them now.
Mark
Edited by msavides
niiiiiiiiiiiiice mark! now i know where you've been hehe :clap:
I actually got off my lazy but last 2 weekends and did something. I did absolutely nothing on my vacation. (BTW I thought we were going wheeling in December) That's ok I had a ton of crap to get done and did nothing, Beside my back was killing me on my vacation so I probably would not have gone anyways.
But Now I got Rock rails I want to go wheeling.
I took some time off on working on my truck, now I am back to working on it again. I should be frequenting the board more now.
Mark
in my case I need to give them a paint job because the oxide is getting them crushed i believe is low weight now and they are rounded around 4 inch diameter
I wish to get a original with the plastic steps and the letters NISSAN on them how much is the cost for one those?
