shimmy in steering wheel
BoneZ
The shimmy I am getting in my steering wheel is not noticeable except in the steering wheel, Passengers can not feel the shimmy at all, The pathfinder still drives straight, but the steering wheel shimmy's almost 1/2" each way as you drive, It seems to have a little less shimmy when you are turning over about 45 degrees. I was hoping someone can help point me in the right direction. At first I thought ball joints, tre's or wheel bearings but can not find any play in them. before you say use the search function I tried and found several post but I could not find one about the steering wheel shimmying and the vehicle still tracking straight. If anyone knows of a post describing a problem like this please post a link. Thanks for your time everyone.
Mine does the same thing. I was told it could be the center link, blown tension rod bushings and idler arm.
Does yours get worse when you hit uneven pavement or little bumps here and there?
Yes it sounds like we have the same problem I will look through those things this weekend thanks for some more ideas. If anyone else has any suggestions please let me know.
Also, drive down some uneven pavement and watch to see if the front wheels flutter around and wobble, etc. Stick your head out the window and have someone else look out the passenger side. That'll tell you which side is causing the problem.
i have the same problem ill try to look into it also. Mine only does it every once i na while on certain roads so i almost thing its the road in my case but it has the same syntoms
Edited by edicer2
Mine is very slight and probably will get worse as time goes on. I was told by my mechanic that the pittman arm was a little loose and the compression rod bushings were shot. It's definitely something with the steering since, like in your case, my passengers don't feel it at all—only I do through the steering wheel.
I agree ;it probably is the bushings on the steering linkage, this is a known problem on an older Pathy. You should also get your tires balanced again as this is the most common cause in my experience. An alignment check would be helpful too. These all contribute to the vibration and the loose bushings on the steering linkage make these more noticable. Good luck ! - glenn
There is no way for the pitman arm to be "loose" aside from having loosened the nut underneath it, which I would be worried about! The pitman arm has ZERO moving parts.
I would rotate tires first to see if it's the tires, then check steering parts for looseness.
  • 3 weeks later...
Just thought I would let you know that the shimmy was coming from one end of my centerlink. The hole that goes through had became egg shaped and was allowing it all to shift around while driving. when the pathfinder was parked you could not feel any movement in it, it was found because i started taking all of the steering apart to find the problem. This is not recommended but since I had no money at the time i found the problem I drought it to a friend that runs a fab shop he welded the area and re machined and drilled it for me 4 free. After putting the front end back together and doing a driveway alignment the pathfinder drives straight with no shimmy. Before anyone starts going off on thats not a safe fix, I am going to replace it on payday and keep this one as a spare part for on the trails. be safe and I hope this helps some others with the same problem.
nothing wrong with welding a whole and re-drilling and reaming it.
