muddawg Posted December 30, 2008 Share Posted December 30, 2008 (edited) I have a 93 SE,I recently did a tune up on the pathy, plugs,plug wirers,clean the Mas sensor changed fluids new O2 sensor,new fuel filter. It ran great for a couple of weeks,Now,when taking off I have to push the gas pedal to the floor and it just crawls alone and then it kicks in, power light come on and revs very high ,trying to get to 60 Mph with the pedal to the floor is hard to do now.Is the pathy dieing? It only has 250,000 on it...LOL! Edited December 31, 2008 by muddawg Link to comment Share on other sites More sharing options...
adamzan Posted December 30, 2008 Share Posted December 30, 2008 Have you checked to see if your transmission is in limp mode? When you turn the truck on the does the power light blink or just come on and then go off? Link to comment Share on other sites More sharing options...
Precise1 Posted December 31, 2008 Share Posted December 31, 2008 Run the ECU codes and see if it tells you anything. B Link to comment Share on other sites More sharing options...
94extreme Posted December 31, 2008 Share Posted December 31, 2008 i bet it's something related to the "reasonly" tuneup. lol Link to comment Share on other sites More sharing options...
Slick Posted December 31, 2008 Share Posted December 31, 2008 when you were fishing around doing your tune up did you move or mess with throttle cables? (i had that problem after i changed my injector rails, it accidentally got adjusted too tight and would cause surging and death) Link to comment Share on other sites More sharing options...
muddawg Posted December 31, 2008 Author Share Posted December 31, 2008 "RECENTLY" LMAO!!. Anyway, Havn't seen the power light blink and I'll recheck everything. Link to comment Share on other sites More sharing options...
muddawg Posted December 31, 2008 Author Share Posted December 31, 2008 I did an ECU check its givin me error 33,Is that the same as an O2 sensor? . Link to comment Share on other sites More sharing options...
edicer2 Posted December 31, 2008 Share Posted December 31, 2008 wiggle the wires that connect to your MAF idk something to try. Link to comment Share on other sites More sharing options...
adamzan Posted December 31, 2008 Share Posted December 31, 2008 I did an ECU check its givin me error 33,Is that the same as an O2 sensor? . Yeah. Try unplugging the 02 sensor under the hood and see if it runs better...I didn't have enough cash to replace mine in the summer, so I forgot about it, and it's been slowly getting worse.... Link to comment Share on other sites More sharing options...
