Everything posted by muddawg
If you pull the heads, do you have to pull rocker arms and springs, i've never done this before,although im sure i can, its got to be better than pullin the engine to get to the broken studs.
I have a 93 se,broken manifold studs on driver side,Im having hell gettin to them, do i need to pull engine? need help. 4 broken studs.
I have a 93 se pathfinder,Im thinking of replacing my engine,I seen on ebay where they have these vg30e engines for around $600-800,Has anyone purchased one of these engines or should I rebuild the one I have.Need some feed back.thanks
I did an ECU check its givin me error 33,Is that the same as an O2 sensor? .
"RECENTLY" LMAO!!. Anyway, Havn't seen the power light blink and I'll recheck everything.
I have a 93 SE,I recently did a tune up on the pathy, plugs,plug wirers,clean the Mas sensor changed fluids new O2 sensor,new fuel filter. It ran great for a couple of weeks,Now,when taking off I have to push the gas pedal to the floor and it just crawls alone and then it kicks in, power light come on and revs very high ,trying to get to 60 Mph with the pedal to the floor is hard to do now.Is the pathy dieing? It only has 250,000 on it...LOL!
GOT IT!
Pantera: Hole In The sky.
MAKERS MARK...Hands down.
Waiting on santa to bring that ALPINE, oooooh yeah!
Me too,I'm back :cool2:
I like it. :cool2:
PANTERA.....COWBOYS FROM HELL!
OH YA,found the problem. thanks 88,the wire coming out of the headlight plug was grounding out.
Hey guys,I have a problem with my right head light. when I turn the high beams on, the right head light- fuse blows everytime.any tips on what i should look for? thanks.
sounds like something i need to do.
Changing the bulb out on the A/C - Heater control
muddawg replied to MatterHorn's topic in The Garage
Hey guys,hopefully I can help,If you have auto temp controls on your ac/heater,there are two diodes, one is in the fan switch the other is in the temp switch.and also there are two bulbs on top of the unit,look for a small door...open it there are two bulbs gray and black,they're dealer items and quite pricey too.I have a pic of the unit hopefully it'll show. -
I HAVE A COUPLE OF LADIES AT U OF L WHO MAY BE INTERRESED.
great ideal jim,we could also vote for calender girl of the year,maybe take up alittle cash from the members to give the winner.just a thought
I installed a 6 disk cd changer,i used the wiring harness that came with it everything hookup fine,didn't have to cut any wires.then i notice that the ac/heater and cigarette lighter didn't work.the blower still works.i check the fuse box everything seems to be ok.my question is,is there a relay somewhere that i'm missing?
Hello everyone,let me start by saying, that this site is great it's very informative.I have a 93/se pathy with all the small problem that it has, I have been able to fix buy viewing this site.I live here at ft,knox ky I've been on some of the tank trails here, it gets alittle sticky at times so far i haven't had to be pull out.(knock on wood ))) ) I enjoy hunting/fishing anything outdoors. Hopefully this summer i'll start adding some cool mods, I built a safri rack last summer out of 3/4 box steel turned out great,added a 50 mm ammo can to hold tow rope/tools etc,I'm looking to add a bullbar soon.thanks jim for a great site , hope to meet ya'll in the forum.
