Torquing ball joints
beastpath
Ok, I am replacing my UCA's, and upper and lower ball joints today.
UCAs went fine, but when I looked at unbolting the upper ball joint from the Knuckle found out there isnt enough room to get a socket in there.
How do I unscrew this nut?
Thx
Very strange. Must be a weird aftermarket ball joint with a longer than normal shaft.
2 options then....
1) Wrench
2) Remove the CV from the knuckle, then use a socket.
Use a wrench....just did those myself a couple weeks ago.
Use the box end and then I had to interlock another wrench onto it to get enough leverage but it'll work.
Make sure you run that nut all the way off before popping the shaft out of the knuckle or you might run into it spinning on you.
creekkid, how did you get the right torque spec when you put it back on?
This is a trick I have used is similar situations. Find another (non critical) bolt, loosen it, torque it to the low end of the spec, put a wrench on it and tighten it just a fraction more. You now know how hard you have to push/pull with the wrench to be in the torque range... ;)
are you talking about the 4 bolts on top? hand tight, basically.
no the spindle bolt
ok, so guesstimate, lol
