95pathyLE Posted November 19, 2008 Share Posted November 19, 2008 my paThy is shifting hard out of first but smooth out of the rest of the gears....its is auto. any suggestions? I just had all the fluids and oil changed so i know its not that. Link to comment Share on other sites More sharing options...
laxman0324 Posted November 19, 2008 Share Posted November 19, 2008 My pathy has always had a firm shift into second, and silky smooth afterwards.. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted November 19, 2008 Share Posted November 19, 2008 I've noticed the same too... If the tranny is cold (except in summer), 1st->2nd shift is always a bid hard; the rest are like butter. Once it warms up though, it's all gravy. Maybe a tranny flush and then throw in some Posi-trak? My buddy's '98 had that issue: he flushed it, refilled it and added Posi-trak, and now it shifts without a hitch. His tranny has well over 300k where mine only has 168k and his shifts as nicely as mine does. Link to comment Share on other sites More sharing options...
sc89 Posted November 19, 2008 Share Posted November 19, 2008 I have a 1998, and had the exact same problem. I just flushed my transmission oil with genuine Nissan ATF, no more than 2 hours ago, and the problem is gone. Dealer doesn't recommend adding any additives, so that's up to you. Link to comment Share on other sites More sharing options...
laxman0324 Posted November 19, 2008 Share Posted November 19, 2008 I don't think it is a "problem" i just think thats the way it is...Dean or someone of the like correct me if im wrong Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted November 19, 2008 Share Posted November 19, 2008 Dealer doesn't recommend adding any additives, so that's up to you. LOL I agree. I told him the same thing to no avail. It ain't my rig so beyond giving him my advice I couldn't care less. It seems to work pretty damn well though Link to comment Share on other sites More sharing options...
sc89 Posted November 19, 2008 Share Posted November 19, 2008 I don't think it is a "problem" i just think thats the way it is...Dean or someone of the like correct me if im wrong Well, seeing as how it forces itself into second gear and now it doesn't, under my ideology I would consider that a problem. If it was meant to be that way, it wouldn't have gone away. Correct? Other possible scenario; it now shifts smoothly into second gear, which is a problem. I should consider paying a visit to the local stealership, to further investigate the situation. Correct? Link to comment Share on other sites More sharing options...
adamzan Posted November 19, 2008 Share Posted November 19, 2008 There was a post around somewhere saying if the trans doesn't shift properly before warmed up it means the wrong (I.e. not nissan) fluid is being used. Link to comment Share on other sites More sharing options...
laxman0324 Posted November 20, 2008 Share Posted November 20, 2008 Mine has always had a firm shift into second, the rest were smooth...i dont think that its unusual so i wouldnt call it a problem Link to comment Share on other sites More sharing options...
sc89 Posted November 20, 2008 Share Posted November 20, 2008 Mine has always had a firm shift into second, the rest were smooth...i dont think that its unusual so i wouldnt call it a problem Did you buy the truck new? If not, at what milage did you make the purchase at? Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted November 20, 2008 Share Posted November 20, 2008 Just some info on this tranny issue... I spoke to my friend who's also a Nissan mechanic, and he mentioned this issue to be pretty common with the first-gen R50 tranny. Specifically around 180,000-200,000 km (110,000-120,000 miles?) is when this tends to occur. It isn't so much an issue as it is an annoyance. But it should be monitored because if it worsens (i.e., shifts become harder and/or louder) it should be checked. Link to comment Share on other sites More sharing options...
95pathyLE Posted November 20, 2008 Author Share Posted November 20, 2008 i got it used from my grandfather. he was the only owner of it and it has about 117000 miles on it Link to comment Share on other sites More sharing options...
Simon Posted November 20, 2008 Share Posted November 20, 2008 There was a post around somewhere saying if the trans doesn't shift properly before warmed up it means the wrong (I.e. not nissan) fluid is being used. That's with the manual tranny. Has nothing to do with the auto. Link to comment Share on other sites More sharing options...
95pathyLE Posted November 20, 2008 Author Share Posted November 20, 2008 no its auto...no its auto. some asked abut the mileage Link to comment Share on other sites More sharing options...
02silverpathy Posted November 20, 2008 Share Posted November 20, 2008 Guys, there is an old TSB out there for this. This is a natural characteristic of the 1st R50's, that was corrected in later years. Warm and cold will change the problem, but not fix it. If you are a little heavier on the go pedal, it won't do it either correct? This is due to its valve body, but changes based on fluids, heat of fluid, and driving style--they all do it from 96-through somewhere in 99. If you really want to change this characteristic, get a shift kit and this will modify everything---*IF* I remember correctly the Trans-Go kit even states it will smooth out 1st -2nd while firming up every other shift! Link to comment Share on other sites More sharing options...
95pathyLE Posted November 20, 2008 Author Share Posted November 20, 2008 ya i have a lil bit of a "heavy" foot. Link to comment Share on other sites More sharing options...
laxman0324 Posted November 20, 2008 Share Posted November 20, 2008 Like I said, not a "problem", its the natural tendency of the tranny Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted November 20, 2008 Share Posted November 20, 2008 Like I said, not a "problem", its the natural tendency of the tranny Exactly! Link to comment Share on other sites More sharing options...
95pathyLE Posted November 21, 2008 Author Share Posted November 21, 2008 ok well thanks everyone, just wanted to make sure my tranny wasnt going to go out on me Link to comment Share on other sites More sharing options...
vengeful Posted November 21, 2008 Share Posted November 21, 2008 If it starts slipping, then you've got to worry. Put a heavy duty trans oil cooler on it, and you'll extend the life immeasurably. Link to comment Share on other sites More sharing options...
95pathyLE Posted November 21, 2008 Author Share Posted November 21, 2008 ok i will do that next time i get the fluids changed. thanks bro Link to comment Share on other sites More sharing options...
adamzan Posted November 22, 2008 Share Posted November 22, 2008 That's with the manual tranny. Has nothing to do with the auto. Automatic transmission: If the transmission does not shift properly until warmed up, make sure it is filled only with Nissanmatic "C" transmission fluid. (1990-95) http://consumerguideauto.howstuffworks.com...athfinder-6.htm I know it says 90-95 but maybe it's the same problem rearing it's ugly head again... Link to comment Share on other sites More sharing options...
